Hotchkis bars hardware - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 06-12-2017, 09:00 PM Thread Starter
super74sport's Avatar
I've been searching the forum up and down and still coming up short. I have hotchkis front and back bars, vogtland springs, and bilstein shocks that im about to install. My question is specifically which front bar end links are you guy's using
super74sport is offline
post #2 of 5 (permalink) Old 06-13-2017, 06:46 AM
gbhs72's Avatar
Just go get a pair of these. They are the heavy duty version, whatever that means to them. I've used them and they are just fine.
Duralast Sway Bar Link SL90HD - Read 2 Reviews on Duralast #SL90HD
Mark: Snowman-33
gbhs72 is offline
post #3 of 5 (permalink) Old 06-13-2017, 06:48 AM
I run the F-Body front bar and when I rebuilt the FE, I just used some standard links from Advance autoparts which had Blue colored Poly Bushings. they were in stock, only $5 a piece and think they were made by Driveworks? Nuthin fancy but they seem to work well.
post #4 of 5 (permalink) Old 06-13-2017, 07:52 AM
juniorwatson's Avatar
Since I love their components and I did everything else in MOOG I used those in the front end rebuild.
juniorwatson is offline
post #5 of 5 (permalink) Old 06-13-2017, 06:28 PM
jasonlachapelle's Avatar
I am using mevotech. The basic ones that have blue bushings, as described above. They were in stock at auto parts place. I would have had to wait 2 days for the HD. The parts store wrote on the bill that the parts have a lifetime warranty since they didn't have the HD in stock.
Jason
1996 Roadmaster Wagon
1995 Caprice Wagon
jasonlachapelle is offline
