Power Steering Flow Control Valve - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 06-25-2017, 01:55 PM Thread Starter
AP9
I'm in the process of replacing my power steering pump and lines. I read in a couple threads that the control valve should be transferred over from the old pump to the new one. After I removed it from the old pump, it looks like just a flare fitting adapter with an orifice (for restriction maybe?) rather than any kind of valve or actuator.
The A-1 Cardone reman pump (20-864) I bought already appears to have such an attachment. Does it really need to be replaced, or does this only apply for variable steering effort Roadmaster/Fleetwood? IIRC, isn't the Caprice p/s system calibrated a bit differently? There's no explicit mention of it in the factory service manual or Haynes manual in the pump replacement section.
Given the fact that the old pump's bearing fractured (in fact I was able to pull the entire pulley shaft out by hand) I really don't want to reuse anything unless I have to.
1996 Chevrolet Impala SS - Dark Cherry Metallic (77U/WA9800)
Stealth bolt mod, 2.5" X-pipe with Pypes Street Pro mufflers & Dynomax resonators, WeatherTech side window deflectors, Hayden 678 "tertiary" transmission cooler & Magnefine inline filter, 9C1 power steering cooling loop, otherwise completely stock
2000 Ford Explorer XLT 4WD (4.0L OHV V6) - Amazon Green Metallic (SU)
2018 Toyota 4Runner TRD Off-Road Premium - Nautical Blue Metallic (8S6)
AP9 is offline
post #2 of 3 (permalink) Old 06-25-2017, 02:24 PM
When I put on a Autozone reman PS pump on my 96 SS the only thing I transferred over was the pulley. I used the pulley remove/install tool Autozone had
post #3 of 3 (permalink) Old 06-25-2017, 03:37 PM Thread Starter
AP9
Thanks. Now if I could only figure out a way to get any of these flare nut threads started, I might have the slightest chance of getting the job done today.
AP9 is offline
