Installing Moog K5208 Upper Ball Joint - Chevy Impala SS Forum
 1Likes
  • 1 Post By Navy Lifer
post #1 of 2 (permalink) Old 06-26-2017, 03:57 PM Thread Starter
juniorwatson's Avatar
Folks,
I am installing new Moog ball joints in my ride, and was wondering if there is a proper way to determine how many washers you're supposed to use with the new joints. I've never seen a part come with literally 6 washers that can stack up to 5/8"!
Thx!
juniorwatson is offline
post #2 of 2 (permalink) Old 06-26-2017, 07:55 PM
Navy Lifer's Avatar
4 bolts, and 1 (lock?) washer per position--under the nut.
You won 2 extra washers, but are not obligated to use them, nor is there any reason to.
Standard content
1slow96 likes this.
Bill Harper
ISSCA #127
[email protected]
Navy Lifer is offline
