help installing front Bilsteins - Chevy Impala SS Forum
post #1 of 37 (permalink) Old 09-30-2017, 01:37 PM Thread Starter
angelo's Avatar
Hi, can't get old ones off.
i seem to have a nut on top only, no jam nut.
my ratchet and impact just spin the stem.
i see no place to even get vise grips CLOSE to the shock to stop the spinning.
any ideas...?
https://photos.app.goo.gl/57s2CisKFTzhoqvu1
https://photos.app.goo.gl/iVG78aUaEpk5PMXA2
-ALF out...
ECIRS #427 ISSCA #01978
CLICK ME !!!
angelo is offline
post #2 of 37 (permalink) Old 09-30-2017, 01:50 PM
schlicky13's Avatar
The way it's supposed to work is you stick an allen wrench or similar in the top of the threaded rod to keep it from spinning, then use a wrench on the nut. You've got a lot of rust there though, so not sure you'd get the nut off without rounding out the inside. In cases of heavy rust or damaged fasteners, I've removed shocks by just cutting off the top of the rod and the nut with a death wheel or reciprocating saw or whatever I can get in there with. Not sure you'll have room to do that, haven't done shocks on one of these cars yet.
Something witty.
schlicky13 is offline
post #3 of 37 (permalink) Old 09-30-2017, 02:09 PM
top of shock piston rod will either have a alan head or 2 sides flat. You use a wrench to hold it and a another wrench to remove nut.
Vise grips also work either on top of old shock rod or grab it anywhere on the piston shaft with vice grips and use a socket on the nut
post #4 of 37 (permalink) Old 09-30-2017, 02:18 PM Thread Starter
angelo's Avatar
I think i'm SOL.
i tried vise grip on piston shaft and just spins still.
I'll check if i have allen wrench to fit in top of psiton rod.
Even if i do all i have is deep 11/16 socket. NO way in hell a box wrench is even getting close...
i'll give it one last try before i say f-it. and have it done.
-ALF out....
angelo is offline
post #5 of 37 (permalink) Old 09-30-2017, 02:29 PM
Had to use a Dremel rotary cutter when nothing else worked. With a small cutting wheel it was a breeze.
https://www.dremel.com/en_US/tools/-...y/27343/rotary
TonySS is offline
post #6 of 37 (permalink) Old 09-30-2017, 02:29 PM
broderick's Avatar
old stuff, shoulda showed on search. get a deep socket on the shock nut on top and a two foot extension and rock it briskly back and forth. I've snapped off many this way. way quicker.
Broderick
on my 4th b-body - 96 b4u
had: 96 9C1 bought new
95 Roadmonster
91 9C1
broderick is offline
post #7 of 37 (permalink) Old 09-30-2017, 03:45 PM
Banned
as was mentioned by another member IMO use a deep socket rock the socket so that the shock rod will break off. too rusted to unscrew it .. keep the lower shock screws on to do this rod breaking .
j cat is offline
post #8 of 37 (permalink) Old 09-30-2017, 05:15 PM Thread Starter
angelo's Avatar
what a cluster F**K.
had to use dremel to get all 3 bolts/nuts off.
i'm tired. autoparts store tomorrow to get all fasterners and bolts i broke.
-ALF out...
EDIT
https://photos.app.goo.gl/Xi1Kap8Qs6ihWmKA3
CLICK ME !!!
angelo is offline
post #9 of 37 (permalink) Old 09-30-2017, 07:02 PM
I see you are in CT. That would explain the difficulty in removing anything on the underside of the car. You may find the speed nuts on the lower control arm difficult to acquire.
post #10 of 37 (permalink) Old 09-30-2017, 08:25 PM Thread Starter
angelo's Avatar
okay, got part 457000 at advance auto parts, the speed nuts, and got doorman part 980-425, the bolts for the nuts.
i checked they at least fit each other. tomorrow i see if the speed nut fits in the bottom of the shock tower like the old ones did.
i got enough for both sides, but boy am i scared to do the PASS side, tomorrow. It's an even tighter spot to work in.
BTW the 3/16 allen head fits in the top shock piston rod PERFECTLY, but there is no room in there to get a wrench on the nut, so that seems useless to me, but i ain't no mechanic.
okay, later.
-ALF out....
CLICK ME !!!
angelo is offline
