Steering Box - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 01-03-2018, 07:21 PM Thread Starter
Steering Box
I need a new steering box for my 9c1 police pkg Caprice (2 1/2 turns lock to lock) but can't seem find one. Everything available is the 3 1/2 turn models....Can anyone help ?
stumac is offline
post #2 of 10 (permalink) Old 01-03-2018, 07:31 PM
Try contacting a rebuilder like Power Steering Products and Services | Lee Power Steering ,and perhaps they may offer suggestions on sourcing one.
post #3 of 10 (permalink) Old 01-03-2018, 07:58 PM
I bought 1 from Advance (think brand was Fenco) and with the ("big35"code -$35 off) discount got it for about $80. Just exchanged my old stock Caprice unit for the Core charge and no one was the wiser.
When I last checked their site, they listed both the standard Caprice box and another "with Police package" which is the quicker ratio.
post #4 of 10 (permalink) Old 01-03-2018, 08:11 PM
Here you go...
https://www.autozone.com/suspension-..._100595?review
Advance does not appear to list 1 anymore.
post #5 of 10 (permalink) Old 01-03-2018, 08:20 PM
Shoot - almost forgot, I have a 96 9C1 I'm parting and the steering box is available if interested. I'd sell it for $100 which is half of the AZ reman part.
post #6 of 10 (permalink) Old 01-04-2018, 08:54 PM
Unless you really need the quicker ratio, the slower one will work as a replacement. Your steering will be more accurate, because you can turn the wheel more for the same output.
Reuse your Pittman arm, because some of the B/D body cars are slightly different. The Pittman arm is not a wear item, so, unless you bend it, it is good for the life of the car.
If you really need the quicker ratio, get yours rebuilt, or use it as a core for a rebuilt one. The bearings and sector shaft should probably be replaced. They are both wear items.
Fred Kiehl is online now
post #7 of 10 (permalink) Old 01-04-2018, 09:18 PM
FYI if you do need to swap Pitman Arms.... That nut takes a "Yuge" Torque and think it was approx 180 Ft Lbs.!! My Torque Wrench only goes up to 150.
post #8 of 10 (permalink) Old 01-04-2018, 09:34 PM
I just put it on as tight as I can get it with a pipe on the breaker bar.
post #9 of 10 (permalink) Old 01-06-2018, 02:12 PM
Rebuild It
I have always had better luck rebuilding original vehicle components than buying rebuilt from a parts store.
I would give Lee power steering a call and see what they can do for you before buying a parts store reman.
Just my experience.
Doug
1996 BBB Impala SS - SSRI, Stage III Flow Master cat back, LT4 ESC, Air Pump Delete, Body mount mod, Brake Bolt Mod with ATE Blue Fluid, HPP III TB By-pass, Felpro diff gasket, Slp Torque Converter, Trans Go, Moog Idler arm, 1516/1517 Bilsteins, F body front sway bar, Ha rear sway bar, Viper alarm, Tint and Chromed OE Wheels, T84\'s/ 80/100 bulbs, 3496 & 168 bulbs. 3.42\'s
2000 Camaro SS was sold for a 2002 k2500 6.0 ext cab short bed, mods are in the works.
Dougsster is offline
post #10 of 10 (permalink) Old 01-07-2018, 09:20 AM
What about this one?
rockauto 9c1 box
If its what ya want, don't forget the RA discount
1995 9C1 LT1
ogre is offline
