Stock height Impala SS springs - Chevy Impala SS Forum
 1Likes
  • 1 Post By madamorr
post #1 of 7 (permalink) Old 01-26-2018, 09:16 PM Thread Starter
Big Wagon Guy's Avatar
Hello all, I'm looking for a set of front/rear replacement coil springs for a 1994 Impala SS. Having a difficult time finding a set of OEM replacment springs. Any know a source or can recommend a brand/part number that are close to stock height?
Thanks in advance.
1994 Silver Caprice WB4
1994 White 9C1
1994 White 9C1
1994 DCM 9C1
1994 Black Caprice
1994 DGGM Buick RMW
1994 Gold RMS
1994 Gold RMS 383/T56
1994 Black RMS
1994 DCM RMS
1994 BBB SS
1995 Silver 9C1 T56
1995 DGGM SS
1995 LDM Caprice Wagon 383/AI T56
1995 LDM Caprice Wagon 383/LE2
1995 Silver RMS
1996 White 9C1 T56
1996 White 9C1
1996 White 9C1
1996 DSB 9C1
1996 Blue 9C1
1996 DGGM SS
1996 DGGM RMS
1996 MABM RMS
1996 Black RMS
1996 Cherry Fleetwood V4P
Big Wagon Guy is offline
post #2 of 7 (permalink) Old 01-27-2018, 07:15 AM
Banned
the height on my 96 IMP is 26.5 in wheel well to ground in the front .
posted in the past some use the caprice springs HD and set them in place and if too high they use cut off wheel to shorten them so the height is what they want .
moog springs were what was recommended but today ??????
after a 1000 miles of use , I would then make them shorter if you want the front end a bit lower , these will take a drop with use ... then after 1K miles do the alignment ..
j cat is offline
post #3 of 7 (permalink) Old 01-27-2018, 01:03 PM
stock springs and tire size?
post #4 of 7 (permalink) Old 01-27-2018, 04:09 PM
Banned
stock tires/wheels and springs .. measured from day one 26.5inches.. right side 1/4 inch lower battery does it .. since new..I have a big heavy battery in it..more weight on passenger side . all the ac components..
j cat is offline
post #5 of 7 (permalink) Old 01-27-2018, 05:50 PM
When I replaced my stock Impala springs, I went with the Moog 7268 spring as it is the same ride height as the original. It is stiffer (748lbs rate), but this car needs a stiffer front spring(IMO). The stock front spring rate I believe is 444lbs rate.
For the rear, I went with a spring from Speedway motors.
https://www.speedwaymotors.com/Tru-C...Track,168.html
These springs are the stock ride height and I would suggest the 200lbs rate for the rear. I believe that the stock rate for the rear is something like 154. The springs from Speedway do come in the 175lbs rate.
Later,
Michael
j cat likes this.
2012 Best of ISSCA; 2013 ISSCA Nats FTD Autocross and Road Racing
1995 BBB: - ERE383 #74 516 FWHP/526 FWTQ
1984 Monte Carlo SS 12.8 @ 104
2005 GTO M6 357.7 RWHP and 358.8 RWTQ PCMFORLESS
madamorr is offline
post #6 of 7 (permalink) Old 01-27-2018, 08:08 PM
I have 175# Speedway's in the back of my 95. As stiff as Eibach's but not as low.
Jim
1968 Camaro -my first car.
1995 Purple Pearl B4U Caprice
1995 Black/White 9C1 Caprice--NADACOP
1995 Purple Pearl L99 Caprice
2012 Alto Gray Metallic 9C1 Caprice--The HoDag-Solo axle back exhaust, improved racing OTR CAI intake.
NADACOP is offline
post #7 of 7 (permalink) Old 01-28-2018, 10:15 AM
Z09B4U's Avatar
750Lbs Front Moog 7268 Ford 150 97-03 Dodge Van 79-80
173Lbs Rear Moog 5419 Caprice 79-96
De-carbon shocks
This gave me near level (slightly higher at back) and a good ride. It is not legal to cut springs in many places so this was the best for me
Do not forget the shocks wear and change.
Z09B4U
Z09B4U is offline
