Converting to SS Springs - Chevy Impala SS Forum
 2Likes
  • 1 Post By 91ss
  • 1 Post By 96 Black
post #1 of 7 (permalink) Old 02-02-2018, 11:52 AM Thread Starter
I purchased a set of used SS springs, and I am not quite sure of the installation orientation. The rear springs have coils that are "tighter" on one end, and I am not sure whether that is top or bottom. From what I've seen, the springs are usually the same from top to bottom. Also, how do I know what way to install the front springs? I'll attach a photo of the fronts for reference.
And just to clarify, these are going on a 96 Fleetwood
soy_chingon13 is offline
post #2 of 7 (permalink) Old 02-02-2018, 01:45 PM
91ss's Avatar
If one end is tighter, they are not stock springs. Regardless, the tighter coils go up. This results in less unsprung weight (axle/control arm end), albeit not much. Some here will say the opposite. But if you look at other applications where the ends are not the same size, like my mustang rear springs, they put the tighter winding at the top.
91ss is offline
post #3 of 7 (permalink) Old 02-02-2018, 01:55 PM Thread Starter
In that case I'll be sure to put the tighter windings at the top. I'm actually in the garage right now, I'm about to install them, I'll attach a picture. If they aren't stock Springs can I assume that they're another brand of lowering spring?
Sent from my SM-G930T using Tapatalk
post #4 of 7 (permalink) Old 02-02-2018, 02:02 PM
91ss's Avatar
Some of the other guys here may be able to tell what brand they are by color or any part numbers on them.
Fyi - Being tighter on one end makes the variable/progressive springs. A number of aftermarket springs are like that.
soy_chingon13 likes this.
91ss is offline
post #5 of 7 (permalink) Old 02-02-2018, 02:40 PM
Oh yah. You're gonna have fun. with some real lower arms, bars and shocks and you're gonna have real fun.
Get the tranny pressures increased when you remove the speed limiter too.
both brake bolt mods too.
post #6 of 7 (permalink) Old 02-02-2018, 02:47 PM Thread Starter
I'll have to look into those mods. I had the transmission rebuilt last year and they put in a shift kit that chirps going into second gear if I get on it.
post #7 of 7 (permalink) Old 02-02-2018, 02:48 PM Thread Starter
Oh, btw, I threw in the rear springs and it didn't seem to lower the ass at all, but it is definitely stiffer.
