Help need eibach with bilstiens - Chevy Impala SS Forum
 1Likes
post #1 of 11 (permalink) Old 02-13-2018, 11:22 PM Thread Starter
Jonathan Si's Avatar
Hi Guys I have a 96 SS and wanted to lower my car down some since i cant look at the front no more. I tried using the stickies but alot of the links are not working.
I was thinking to get the eibach pro kit with bilstien shocks but not sure which bils to get the b6?
also from pics I have seen all lowering sprinfs still dont have the rake look more so the rear looks lower which i dont like. if i was to get the eibachs has anyone cut a hair of the fronts to make car even?
Jonathan Si is offline
post #2 of 11 (permalink) Old 02-14-2018, 06:10 AM
Blue Wail's Avatar
Eibachs or Hotchkiss springs should work well.
Also the Monroe Severe Service shocks are a good alternative to
Bilsteins at half the cost. We use them to race at the circle track.
Nab
Blue Wail is offline
post #3 of 11 (permalink) Old 02-14-2018, 11:16 AM Thread Starter
thanks for reply I thinking i am just going to cut the front stocks springs to match better the rear. I dont really want to go lower then the stock rear now so no point on eibachs..
I will go with bilsitens b6 since i like them on my other cars..
quick question i notice my rear is 1" difference in height from the left to right. is this normal on the ss?
post #4 of 11 (permalink) Old 02-14-2018, 12:11 PM
Recommended: read 50 threads on cutting coils; cut once. Use a cutoff saw and not a torch or you're gonna p off a lot of guys here.
And that difference not normal. Bent stab bar is my first pick, bound control arm bushing, sacked out coil, even a galled shock. You can even check for the famous ""control arm hole punched in the wrong place on the frame" problem, but that may be for only certain years or production run. Search.
A real stretch can be a problem from the front manifesting itself in the rear.
post #5 of 11 (permalink) Old 02-14-2018, 12:12 PM
No,you've likely got a bent sway bar. Or,and improperly installed front spring. Do not cut the Eibach's...
1slow96 is online now
post #6 of 11 (permalink) Old 02-15-2018, 04:46 PM Thread Starter
Thanks for the help guys means a lot.
I am going to stick with the stock springs and cut them in the front little at a time like other said in other postings.
My understand is all I need to buy to complete the job at the fancy bump stops and also remove some shims to help alignment
I will be ordering full set front and rear bilstiens b6 shocks
is there anything else i need to order before I Start the job?
post #7 of 11 (permalink) Old 02-15-2018, 07:01 PM
I would buy these Moog 7268 Coil Spring Set from Amazon, It lowers the Impala down about 1 inch and handles so much better. I used them 8 or 9 times for SS rebuilds. I keep a few pairs in stock, a set will be going in my 1995 Roadmaster SS build soon. you can even cut then if needed. but all I would go would be 1/2 coil
KDB50SS is offline
post #8 of 11 (permalink) Old 09-24-2018, 01:15 PM
I had the Monroe Severe Service shocks on my '96 RMW and they were terrible. Too much high-speed damping, so I'd feel all the bumps that the car would hit, and too little low-speed damping, so the car would wallow around turns or over undulations in the road's surface. It was literally the worst of both worlds--terrible comfort and terrible handling. My '94 Caprice wagon has the Bilsteins and they are night-and-day difference better than the Monroe Severe Service shocks.
--'94 Caprice "SS" wagon, 0.30 over, high-volume oil pump, LT4 hot cam, 1.6:1 rockers, ported aluminum Corvette heads, shorty headers, PCM4Less tune, 4.10s, shift kit, side-exit dual exhaust with Flowmasters, OR X-pipe, F-body gauge cluster, Bonneville front and rear seats (working electrics), Bravada console shifter, Bilsteins, 12.7:1 Impala steering box, Boss 338s with 255/45R20s, bunch of other stuff I'm forgetting.
--'04 Mustang Cobra, '15 Audi S4
--1125R, 1050, VMax, VFR800, DRZ-400E
TheFleshRocket is offline
post #9 of 11 (permalink) Old 09-25-2018, 02:49 PM
Toms9C1's Avatar
You get what you pay for. If your on a budget, Monroe is a good choice.
Tom
ISSCA Member #2540
95 B4U: LT4 LE Cam 1.6 RR Eibachs 17" SS Whls K&N XPypes Mech fan delete+Gary's wiring harness RM Lthr seats Imp SS Rear Disc Eaton Posi Motive 3:73's Moser Axles Stainless brake lines NEW 4L60E/Dacco 2000
94 9C1: Eaton Posi 3:08's XPypes Stainless Brake lines
95 L99 DCM: SS Clone Vogtland springs Monroe SS shocks XPypes Front end overhaul w/Alum bushings
96 RMW Woody Black / Red guts
http://badass-of-ne.forumotion.com/forum.htm
Toms9C1 is offline
post #10 of 11 (permalink) Old 09-25-2018, 03:09 PM
By the time you replace the Monroe's one time... You'll be at,or exceeding the cost of the Bilstein's which offer far better handling,and life...
Toms9C1 likes this.
