Jeep steering shaft year - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 06-12-2018, 11:32 AM Thread Starter
Big Jack's Avatar
Hi guys,
I did a few searches trying to find what year of Jeep steering shaft will fit, couldn't find a definitive answer.
I understand that there are more than 1 type that can be made to fit, so what year Jeep shaft requires the least amount of hacking to fit?
Thanks
Remember, when not sure what to do, hit the throttle.
It may not end well, but at least it'll end the suspense.
Big Jack is offline
post #2 of 10 (permalink) Old 06-12-2018, 02:15 PM
4x4high's Avatar
Not sure of the year but I have one I'm willing to sell, bought it from a member here years ago and have never gotten around to I stalling g it. PM me if you're interested.
1996 DGGM Impala SS
4x4high is offline
post #3 of 10 (permalink) Old 06-12-2018, 02:28 PM
Z09B4U's Avatar
Have a look at these two links.
https://bangshift.com/general-news/t...hed-rag-joint/
https://www.impalassforum.com/vBullet...what-look.html
Be sure of what you need. Junkyard shafts may also be worn out and may not be correct for your use because they have been changed out for other designs.
What region of Canada?
Z09B4U
Z09B4U is offline
post #4 of 10 (permalink) Old 06-12-2018, 10:49 PM
I stopped pulling them, because I had to pull 4 to get a good one. If it clicks when twisted, the U joints are worn out. You can get a new one on Amazon for about $120.
The earlier ones 91-93 are better. You can use 94 and newer ones (of the same design), but they tend to disconnect at the upper universal bushing. You can weld the shaft to the upper joint fork to make them safe.
post #5 of 10 (permalink) Old 06-13-2018, 07:20 AM Thread Starter
Big Jack's Avatar
I'm in Nova Scotia
Big Jack is offline
post #6 of 10 (permalink) Old 06-17-2018, 12:41 AM
TGO
Why even bother? Just go borgeson.
2001 Corvette ZO6
1995 Impala SS - H/C/I - BBB
TGO is offline
post #7 of 10 (permalink) Old 06-17-2018, 05:48 AM
Have you priced Borgeson? A new Jeep shaft is about the price of ONE universal joint from Borgeson. It will also work just as well as the Borgeson setup.
post #8 of 10 (permalink) Old 06-17-2018, 10:38 AM
TGO
Yes I have.
I value my life a lot more than a few hundred bucks.
2001 Corvette ZO6
TGO is offline
post #9 of 10 (permalink) Old 06-17-2018, 11:11 AM
There is no danger in using the Jeep shaft, as long as you know the weak points, and fix them. A couple of hundred dollars frivolously spent is still a couple of hundred dollars you no longer have. If you want to spend a couple of hundred dollars more for the same results, that is up to you, but safety is not an issue with the Jeep shaft, especially if you buy a new one.
post #10 of 10 (permalink) Old 06-18-2018, 12:13 AM
TGO
Anything that requires modification to make it "safe" - in your own words - is not safe.
2001 Corvette ZO6
TGO is offline
