Rear Shock Relocation Brackets? - Chevy Impala SS Forum
 1Likes
  • 1 Post By 4DoorSS
post #1 of 7 (permalink) Old 06-28-2018, 09:22 AM Thread Starter
sonuvah's Avatar
Question Rear Shock Relocation Brackets?
Anyone using these? I thought it might be a good idea to use them in conjunction with the 3/4" extended control arms and driveshaft I've already installed. They're available at Streettrends. Are they only for bagged applications or what? If not, any special tips on how and where they should be installed?
"Monk in Training"
sonuvah is offline
post #2 of 7 (permalink) Old 06-28-2018, 09:51 AM
94MSP9C1's Avatar
Originally Posted by sonuvah View Post
Anyone using these?
These what? I do not see any picture? I only see the words "Attached Thumbnails" but there is no picture and none appears if you try to click on the words?
Mike--94MSP9C1
94MSP9C1 is offline
post #3 of 7 (permalink) Old 06-28-2018, 10:10 AM
Z09B4U's Avatar
Thumbnail is showing on my browser.
I would worry about the coil spring upper mount location much more than a 3/4inch offset of the shock mount. 3/4inch offset over the length of the shock would change the angle only a few degrees. I think I have seen some vehicles with the shock mount on the axle being on the front of one side and the back of the other.
Z09B4U
Z09B4U is offline
post #4 of 7 (permalink) Old 06-28-2018, 05:27 PM
Banned
the bolt design is china crap.. bolt shoulder must be much longer..
j cat is offline
post #5 of 7 (permalink) Old 06-28-2018, 05:59 PM
They're available at Streettrends. ?
You may want to look at a different vendor to get these. See recent post on ST's as they seem to just be taking people's money. Also not a big fan of pushing the rear back 3/4" just to center the look of the wheel. This seems to throw off the geometry of the rear suspension and really no benefit other than the look.
Yes, IIRC, the 70-81 camaro/firebird had this staggered rear shock mounts. They were plates that mounted under the axle with the shock mounted to that plate. The plates were side specific and the LR shock mounts behind the axle and RR shock mounts in front of axle.
1slow96 likes this.
post #6 of 7 (permalink) Old 06-29-2018, 06:54 PM
Sshockr's Avatar
I was less worried about the shock angle than the resulting spring angle.
-Brian
'95 B4U LT1/T56 in Purple Pearl. 24x 355 with I believe most of the bolt-ons.
'63 C10 LT1/4L60E from B-Body. Rides like a Cadillac thanks to air bags.
'06 GTO LS2/T56 Torrid Red with CAI and Borla Cat-back thanks to the lady who rear ended me.
Still in Wichita.
Sshockr is offline
post #7 of 7 (permalink) Old 06-30-2018, 11:21 AM
-Brian
That is just 1 of the issues caused by pushing the Rear back 3/4" that concerns me. The Bottom mount changes but the top mount for the Spring Perches stay where they were, so now there is more of an angle in the Spring. Like I said, the Geometry is completely changed when you do this mod just to center the Rear Wheels. Just not worth it IMHHO but many here have done it.
Any place to get rear shock relocation brackets besides StreetTrends?
Any other way to accomplish this?
Why do I keep thinking of Navy Lifer when rear shock relocation brackets come to mind?
You may be thinking of the Upper Shock Mount U-Bolt kits he sells.
