Power Steering Box leak - Chevy Impala SS Forum
 1Likes
  • 1 Post By babywag
post #1 of 5 (permalink) Old 08-28-2018, 12:07 PM Thread Starter
What is the most typical power steering box leak. Mine is dripping on the ground..ever so slightly.. but I haven't really investigated yet.
94 + 95 + 96 = 3
the blur is offline
post #2 of 5 (permalink) Old 08-28-2018, 01:01 PM
juniorwatson's Avatar
Just to be clear, are you referring to the gear box mounted to the frame, or the P/S fluid reservoir?
I assume the gear box, but just thought I'd ask the question...
I've never experienced any great leaks myself outside of a small amount of fluid I've seen around where the fittings for the lines are on the top.
I'd assume the seal on the bottom side where she connects to the pitman arm would be the most likely culprit. I've never seen on any of my vehicles, the input shaft leaking, but it's certainly not out of the question.
juniorwatson is offline
post #3 of 5 (permalink) Old 08-28-2018, 03:28 PM
The P/S pump leaks. I had a bad one for a while. Replaced the pump, now the steering box leaks. Get ready for a PITA.
Jim B.
fbi9c1 is offline
post #4 of 5 (permalink) Old 08-28-2018, 03:34 PM
I've had good results using Lucas P/S stop leak.
post #5 of 5 (permalink) Old 08-28-2018, 05:21 PM
babywag's Avatar
Output shaft seal...easy to replace BUT to do it 'right" box should come off and clean/polish shaft.
Many I've seen the shaft is dirty/rusty and just slapping a new seal @ it w/o cleaning them up would almost guarantee a leak again.
Here is a before shot of what I'm talking about.
Mine leaked pretty good 7 months ago.
Removing the shaft, cleaning/polishing shaft, replacing the bearing and reinstall it is both leak free and way less shaft play.
Bearings are almost always worn as well.
gbhs72 likes this.
babywag is offline
