Tubular controls arms (front) - Chevy Impala SS Forum
post #1 of 28 (permalink) Old 12-05-2018, 09:37 AM Thread Starter
GreenWitINv's Avatar
Does anyone have experience with swapping oem front control arms for 70-81 Camaro tubular control arms? Supposed to be an exact fit and more affordable.
GreenWitINv is offline
post #2 of 28 (permalink) Old 12-06-2018, 11:59 AM
boofers's Avatar
try this site:
http://www.p-s-t.com/
I have no experience with them but for the B-Body a set runs about $840
1996 BBB, 396ci Golen LT4, Yank 3600, TransGo shift kit, 3.73s, P71 MMC driveshaft, CIA Tri-Y Gen II, X-Pipe, Dynomax UltraFlo exhaust, Hotchkis Sway bars & Springs, Bilstein Shocks, UMI extended control arms, ODBI conversion, all installed and tuned by Mike Harris
boofers is offline
post #3 of 28 (permalink) Old 12-07-2018, 08:09 PM
I haven't heard that one but I do have that year Camaro front sway bar on my Impala.
nickss96 is offline
post #4 of 28 (permalink) Old 12-09-2018, 12:13 AM
As long as you don't have the 5/8" ball joint knuckles, they'll bolt right in. I've got the SPC F-body lowers in my car, and uppers for that matter.
akio is offline
post #5 of 28 (permalink) Old 12-11-2018, 10:19 AM
Is that 5/8" measured at the small end of the taper (threaded end)?
1996 White 9C1 - Destined to be majorly modified
1995 White 9C1 - Destined to be mildly warmed over
1995 DCM Impala SS - Trashed by previous owner(s)
1972 Orange Firebird Esprit - Destined to be restored
indychevyman is offline
post #6 of 28 (permalink) Old 12-11-2018, 07:11 PM
Yes, the threaded end of the Balljoint is 5/8" vs the Stock which is 9/16". The other major difference in a 5/8" Balljoint is the Base of the BJ that gets pressed into the Lower Control Arm is also slightly larger.
The 5/8" BJ "setup" requires a different Spindle for the threaded end and a different Control Arm for the BJ to be pressed into. This setup was only available on late 95-96 9C1 cars.
I added this setup years ago so be sure of your setup as these Tubular arms may only be available for 9/16" BJ's. If you have no history on your car, be sure these will fit Hate to see you go "Tubular" and have it all tore apart and realize..."Damn!!" I think some companies offered a 5/8" tobular lower arm but not sure.
Here is my thread on swapping from 9/16 too 5/8 which may help explain all this...
https://www.impalassforum.com/vBulle...ps-part-s.html
EDIT - I can't believe how long ago it was Bill put this thread out there....5 Years ago. Anyway, there is good info there and it looks like Speed tech offers both versions of Control Arms. I updated that thread with a new link to their site...
https://www.impalassforum.com/vBulle...l#post12096140
post #7 of 28 (permalink) Old 12-19-2018, 09:19 AM Thread Starter
Received CPP control arms for 81 Camaro. These SHOULD bolt right in. Compared Ball joint. OEM crown nuts are interchangeable. The 5/8 ball joints are limited to 95-96 RPO 9C1/9C3 police and 9C6 taxi options. I have a 96 Impala. Wish me luck! Will post update after the holiday.
post #8 of 28 (permalink) Old 12-20-2018, 06:25 PM
Is this the correct control arm? https://www.speedwaymotors.com/1970-...-Arm,2122.html
Also, what does this mean: This upper control arm for 1970-1981 Camaro is designed to be used with the stock mount. Available in 8", 8-1/4", 8-1/2", 8-3/4", 9", 9-1/4", 9-1/2". This control arm requires the use of a K6024-style ball joint, which is equivalent a 1963-71 Chevy pickup style upper ball joint. It will have a 7 degree tapered stud and therefore, the stock Camaro spindle must be reamed to fit the pickup ball joint.
Will these arms require any modification to install on a b-body? Ball joints, spindle, etc.?
1995 Cadillac Fleetwood Brougham BBB - Build in progress
Caddylack is offline
post #9 of 28 (permalink) Old 12-20-2018, 09:40 PM
You don't want that for a street car. It's basically a disposable control arm for circle track and similar racing, available in those lengths for suspension tuning, and like the description says, you have to ream the top end spindle taper to use the designed-for ball joint. (Stock UBJ is K5208)
akio is offline
post #10 of 28 (permalink) Old 01-05-2019, 09:09 PM Thread Starter
I am wrapping up the install on my CPP Tubular control arms and want to send an update. Let me start by saying I needed to replace the idler arm and some tie rod ends so I bought the 10 or 12 piece HD steering kit as well as the tubular control arms. Controls arms are the same for 80-96 Impala & Caprice, 70-81 Camaro. I only had to use the UBJ from the rebuild kit (simple swap). Other than that the control arms bolted right in. Not quite done yet,, I had to rent a different spring compresser, but will send final pics tomorrow when it’s all buttoned up.
