Need Help Finding Front Control arm Fender seal - Chevy Impala SS Forum
 1Likes
post #1 of 13 (permalink) Old 01-19-2019, 10:29 AM Thread Starter
Hey guys I did some suspension work on my Ď96 SS and I wanted To replace the seal that is right above the control arm. It clips to the fender. I cant Seem to find a replacement and I also Donít know the correct name for the part. Thanks in adavance.
Johnnypegs is offline
post #2 of 13 (permalink) Old 01-19-2019, 11:08 AM
I think what u may be looking for are referred to as Splash Shields or Baffles. There are a few re-pop options out there....
https://www.impalassforum.com/vBulle...s-baffles.html
The kit I got also included the 2 up by the radiator and a package of new mounting pins.
post #3 of 13 (permalink) Old 01-19-2019, 11:26 AM Thread Starter
Yes thank you!
post #4 of 13 (permalink) Old 01-19-2019, 12:26 PM
+1 for rubbertherightway.com
did the 96 SS and my 67 Camaro with their shields
post #5 of 13 (permalink) Old 01-25-2019, 01:25 AM
Send a message via Yahoo to rmont917
I agree rubbertherightway.com $20.00 from a San Diego Ca. company. USA!
rmont917 is offline
post #6 of 13 (permalink) Old 01-25-2019, 06:21 AM
juniorwatson's Avatar
This is interesting to know, and great to have another bookmark for this product, as I used (Scratching my head...) Classic Industries
juniorwatson is offline
post #7 of 13 (permalink) Old 01-25-2019, 04:36 PM
Banned
I dumped those OEM splash shields 20 years ago .. reason is they are not rebust and are not big enough to keep the water out of the engine bay.
I fabricated splash shields with rubber roofing material .. guess how this worked for 20 years LOL.. still perfect . also on the cheap ..
this is rubber roofing used on flat roofs ... tough material UV strong .
GM material breaks down in a couple of years POS material.
on my 2000 truck I used this also on the front and the rear .... along with fiberglass mud guards ..
grandpas wagon likes this.
j cat is offline
post #8 of 13 (permalink) Old 01-25-2019, 05:06 PM
Originally Posted by j cat View Post
[SNIP]
You can also use the thick rubber matting material used between gas tanks and the sheet metal body like all the old classic cars with metal gas tanks used to have. McMaster Carr sells it.
post #9 of 13 (permalink) Old 04-06-2019, 06:43 PM
Fender seal
I used rubbertherightway.com they are at 7158 Convoy Ct , San Diego ca. 92111 1 866 789 7879 $ 20. set brand new fits perfectly, I just found their phone number & address . they have catalogs they can send out if you ask.
rmont917
rmont917 is offline
post #10 of 13 (permalink) Old 04-08-2019, 05:08 PM
What great info! Mine are all split and ugly, and I assumed I was just going to have to live with it. Nice to hear all the options. Thank you all for sharing!
VManganese is offline
