Spring setup help Moog 5552 OEM 482086 - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 02-01-2019, 01:55 PM Thread Starter
1995 RMS with 17" SS wheels, not sure which size tire I will use, probably stock.
Front springs Moog 5552 w/ Koni 8040 1087
Rear GM 482086 ( 1991 9C1) w/ Bilstein 24-009294
Will this work? Is there a better front option?
Goals: need ground clearance for rough roads, want a sporty ride not the mushy gushy FE1.
I will be upgrading brakes and bars too.
Any suggestions or help with recommendations is much appreciated.
I prefer new springs without any cutting.
Thanks, Walt
95 Buick RMS
Stock
TurboWalt is offline
post #2 of 5 (permalink) Old 02-01-2019, 09:06 PM
Z09B4U's Avatar
I went with factory rate Bilstein and these springs:
Moog 7268 Front Ford 150 97-03 Dodge Van 79-80 750Lbs
Moog 5419 Rear Caprice 79-96 (9C1?) 173Lbs
Front springs Moog 5552 are 543Lbs
You post the moog equivalent for the rears
I do not think you would notice much difference with your choice. The 750Lbs firm up the handling and are a little higher than factory.(0.16")
I would stick to one shock manufacturer or get adjustable ones. I would be afraid different design targets of different shock companies could do weird things.
The forum search may help you or try searching from outside and include Impala forum. I went through old posts one at a time before I bought my springs.
This is one of those posts:
https://www.impalassforum.com/vBulle...h-springs.html
Z09B4U
Z09B4U is offline
post #3 of 5 (permalink) Old 02-01-2019, 09:14 PM Thread Starter
GM 482086 rate should be 184 lbs.
95 Buick RMS
Stock
post #4 of 5 (permalink) Old 02-01-2019, 09:48 PM
Suggestions:
Front -> Moog 7268
Rear -> Speedway Motors TrueCoil 200lb : https://www.speedwaymotors.com/Tru-C...sku=252514-200
Shocks -> QA1 Stocker Star Shock Adjustable.
Gives stiffer ride than stock, but handles well for Autocross and Road Racing.
2012 Best of ISSCA; 2013 ISSCA Nats FTD Autocross and Road Racing
1995 BBB: - ERE383 #74 516 FWHP/526 FWTQ
1984 Monte Carlo SS 12.8 @ 104
2005 GTO M6 357.7 RWHP and 358.8 RWTQ PCMFORLESS
madamorr is offline
post #5 of 5 (permalink) Old 02-02-2019, 07:20 AM
MWP
This link from last year describes the part numbers + results for my Fleetwood: Regular Bilsteins, cargo coils, Airlift bags for load/tow. No change to rear bar, still need to change front bar from FE1 to the Impala size.
https://www.impalassforum.com/vBulle...l#post12086420
MWP is offline
Similar Threads
Moog 5552 springs installed dogma Suspension 0 04-12-2011 07:56 PM
Please help to decipher the Moog Spring Chart Marky Dissod Suspension 15 04-04-2011 09:11 AM
moog coil spring d.cherryss Parts for sale/wanted 4 07-10-2009 03:48 PM
FS: 1990 9c1 Rear Springs 482086 NEW Heavy Chevy Parts for sale/wanted 5 07-08-2008 11:35 AM
MOOG vs. oem 94fleet Suspension 0 04-10-2006 02:28 PM
