Any reason to Replace Pitman Arm - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 02-17-2019, 11:42 AM Thread Starter
impala79's Avatar
I am getting ready to replace my steering linkage from spindle to spindle and am wondering if there is any reason to bother with the pitman arm. There appears to be no wear surfaces on it.
Feedback please?
Greg
\'96 DGGM B4U, 147k - PMCAIS, Impala grille, wheels, and tail lights, SEO p/s cooler, slotted rotors, Hawk pads, Scott Mueller body bushing mounts, Bilstiens
\'95 Caprice Classic Wagon, MGR, 218k - PMCAIS, TB Bypass, SEO ps cooler, SEO hoses, WX3 wheels (in the summer) - Rest In Pieces 6/13/12 1630
\'83 Caprice Classic Wagon, 117k Rest in Pieces 10/23/05 1306
\'75 Caprice Classic Convt, 61K The original LT4 (400 SBC)
impala79 is offline
post #2 of 4 (permalink) Old 02-17-2019, 02:45 PM
Not really...It's a non wear item. The only time I can see replacing it is if if got bent in an accident or if the hole that the center link mates to got "wallowed out" somehow.
If you do have to replace it, make sure you have a torque wrench that goes above 150lbs. IIRC - the torque on the nut is something like 180 lbs. I swapped steering boxes and ran into this issue. Just used my wrench at the highest setting, then used a breaker bar on my wrench to tighten the nut a little bit more.
post #3 of 4 (permalink) Old 02-17-2019, 03:58 PM
Leave it be....
1slow96 is online now
post #4 of 4 (permalink) Old 02-17-2019, 08:00 PM Thread Starter
impala79's Avatar
Thank-you!
Greg
impala79 is offline
Similar Threads
Pitman and Idler Arm Support System 96GreatWhiteNorth Suspension 3 03-18-2009 10:54 AM
Steering Box / Pitman Arm Replacement dloch Suspension 6 11-30-2008 06:30 PM
Loose near pitman arm....Mostly likely centerlink??? snakey5138999 Suspension 8 10-01-2008 03:33 PM
Which puller for Pitman Arm? Moparman Suspension 1 08-23-2008 09:23 PM
Pitman arm ghetto wagon Suspension 1 04-14-2008 07:13 PM
