Moog Problem solver vs Proforged - Chevy Impala SS Forum
 3Likes
  • 2 Post By 96 Black
  • 1 Post By schlicky13
post #1 of 9 (permalink) Old 02-17-2019, 12:25 PM Thread Starter
impala79's Avatar
For steering linkage sidle to spindle...Proforged comes in one complete package. Those of you who have used either, what has been your experience?
Greg
\'96 DGGM B4U, 147k - PMCAIS, Impala grille, wheels, and tail lights, SEO p/s cooler, slotted rotors, Hawk pads, Scott Mueller body bushing mounts, Bilstiens
\'95 Caprice Classic Wagon, MGR, 218k - PMCAIS, TB Bypass, SEO ps cooler, SEO hoses, WX3 wheels (in the summer) - Rest In Pieces 6/13/12 1630
\'83 Caprice Classic Wagon, 117k Rest in Pieces 10/23/05 1306
\'75 Caprice Classic Convt, 61K The original LT4 (400 SBC)
impala79 is offline
post #2 of 9 (permalink) Old 02-17-2019, 12:51 PM
Never used ProForge. All those of us using Moog PS seldom have reason to switch.
Sinister and schlicky13 like this.
96 Black is online now
post #3 of 9 (permalink) Old 02-17-2019, 02:37 PM
Don't think you can go wrong with either but prefer Moog. I did use a Proforged kit years ago only due to a Group Purchase that was going on here at the time. The pricing was right and so were their reviews.
Then years later when upgrading to 5/8" Balljoints, I decided to replace everything again and went with all Moog parts that time. The Proforged pieces still seemed to be fine but just decided to go all new Moog again while things were apart. I did keep the center link and idler arm and just replaced tie rods and Balljoints with Moog parts and GM hardware.
post #4 of 9 (permalink) Old 02-17-2019, 08:05 PM Thread Starter
impala79's Avatar
Thank you...I have not heard anything bad about either. The only difference that I can determine is that the Proforged is powder-coated black
Greg
impala79 is offline
post #5 of 9 (permalink) Old 02-19-2019, 11:10 AM
SSandman's Avatar
Wow, I've been way out of the loop. I went with Pro Forged back when they were still PPM and the idler arm was a very nice piece. The Moog "problem solver" was seriously beefy, a noticeably more robust casting than the factory part, and was still going strong on my 94 many miles after all the other parts store brands I tried wore out.
I have heard complaints about certain Moog parts being outsourced now, quality slipping etc.. but I don't know if this is true with all Moog parts, some, or if it has been rectified. I remember years back when one brand would be good for years, now it seems like brands switch manufacturing plants so often and outsource to different places that you never know on a year to year basis what you'll be getting quality control wise.
SSandman is offline
post #6 of 9 (permalink) Old 02-19-2019, 07:22 PM
Sinister's Avatar
Moog has different product lines. When ordering parts go for the Problem Solver line because it is their premium product. The lesser products are cheap, Chinese crap.
I bought all of my PS parts from Rock Auto last year, all US made and all very high quality.
1995 Caprice Wagon
Sinister is offline
post #7 of 9 (permalink) Old 02-19-2019, 10:28 PM
JimCT_9C1's Avatar
I've used both Moog Problem Solver and Proforged, no issues with either.
Just pointing out Proforged still offers the tall upper ball joint if that's of interest to you.
Jim
1995 Caprice 9C1
Dynomax Catback, K&N Cold Air Kit, 3.73s, Other Little Stuff ...
CT Tri-9, ECIRS, ISSCA
JimCT_9C1 is offline
post #8 of 9 (permalink) Old 02-20-2019, 05:09 PM
schlicky13's Avatar
To tell the difference with moog product lines, the "problem solver" stuff normally has a K in the part number, the cheaper chinese line usually has an R in the part number. At least that's been my experience since they started introducing it. In some cases I've also seen them discontinue K parts after the R product line came into existence, but not anything on our b-bodies. I've only seen that so far on some other stuff I've worked on.
Sinister likes this.
Something witty.
schlicky13 is offline
post #9 of 9 (permalink) Old 02-20-2019, 05:43 PM
Banned
I replaced the idler arm moog back in 1997 .. brought the 96 Imp to dealership they put it on lift the idler arm moved more than 1/8 inch up/down they said that is normal I said that is B/S.. I have the GM manual and showed them the test procedure.. they said screw you.. I said good by azzhole..
put the Moog idler arm on 1997 and it is still on .. no problems ..
a few years ago I had to replace my trucks GM inner tie rod well the Moog tie rod did not hold up .. so I got another one free warranty and still good..
possible manufacturing defect on the tie rod ..
I do grease my vehicles in the fall and in the spring .
my 1983 sedan I did have to replace a good amount of steering parts Moog and that was at 250K miles .. all those parts worked good till I sold it at 375K miles.
j cat is offline
Similar Threads
MOOG problem solver tie rod ends new in box bowtie402 Parts for sale/wanted 0 10-05-2008 11:42 PM
Idler arm MOOG - "problem solver" what problem ??? Jabpir8 Suspension 11 06-10-2008 08:01 PM
Help, please...Missing article on Moog Problem Solver Idler Arm Installation... 4501 Safari Suspension 3 03-18-2008 04:12 PM
Moog Problem Solver ak47 Suspension 15 08-22-2001 12:20 PM
