Control Arm drain Holes - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 02-21-2019, 10:56 AM Thread Starter
gbhs72's Avatar
I've looked and haven't found anything about this. If the front springs are cut. Don't you have to be sure the top fits the pocket on the upper control arm and then the bottom should be between the two drain holes on the bottom? I may be missing something but it seems as if you could only cut approximately one coil at a time. Is my reasoning correct? Seems sort of stupid but I wonder about a lot of things.
Thanks all.
Mark: Snowman-33
gbhs72 is offline
post #2 of 9 (permalink) Old 02-21-2019, 02:01 PM
Blue Wail's Avatar
The top of the spring sits in the frame perch, not the upper control arm
so it can be oriented or clocked in any position. Yes, bottom of spring
should be in drain holes in lower A arm.
Nab
April's Sparkle Cat
383 LT1 12:1 flat top + 75 shot
11.66 @ 117 at SSHS17 Nov 11, 2017
2017 12.0 Index Champion
4140 lbs. w/ driver. front sway bar ON
Powered by 4L80E! (controlled by LT1 pcm)
Blue Wail is offline
post #3 of 9 (permalink) Old 02-21-2019, 02:54 PM
Nab +1
You can always tell which is the top end of a front coil. It's the end you can set on the ground without it tipping over. Guys who don't know about clocking the bottom end between the holes find a major cause of unequal ride ht. afterward.
Mark, I wonder about alot of things too. Right now it's how much suction will hold in a closed cooling system to allow me to change a leaking drain petcock without too much AF loss v. draining the whole system. I'll let y'alls know when it's 20 degrees warmer out, or Saturday, whichever comes first.
post #4 of 9 (permalink) Old 02-21-2019, 03:38 PM
One method is to install a trim screw up through the drain hole. This insures that both will be open afterwards. Rotate spring until contacting screw,and complete installation by removing screw.
post #5 of 9 (permalink) Old 02-21-2019, 04:53 PM
95wagon's Avatar
The spring is supposed to completely cover the first "drain hole" and not cover the second.
Next time you guys have a spring out take a LONG look up at the spring pocket.
It is not completely flat , and does have a subtle indent where the end of the top of the spring is supposed to fit.
This because the "B" body does not use a finish ground end that can go anywhere.
It is just flatted with a raw end, preventing it from sitting square on a flat surface
It is not very big , and add the rubber isolator, that is how people have gotten away with less than full cuts on the lower for ever.
Not indexing the top will cock the spring a little bit, but as I said people get away with it all the time.
Other guys will experience the coil rubbing the side of the pocket.
Mine are cut one full coil to keep both top and bottom aligned
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
11.79 @ 120.65
LS7 T56 drag video
My Wagon
My W-31 Cutlass
95wagon is offline
post #6 of 9 (permalink) Old 02-21-2019, 05:20 PM Thread Starter
gbhs72's Avatar
Nab
Doh!!!!! Head Slap. I did mean the spring perch. But there is a notch for the spring. Correct? Doesn't the end or the top of the spring go in a designated pocket in the perch? If the spring doesn't go to that point is seems as if it could turn a little bit and cover the drain holes. I may be over thinking this but I have thought of it for over a year now. Keep me aligned here.
Thanks all,
Mark: Snowman-33
gbhs72 is offline
post #7 of 9 (permalink) Old 02-21-2019, 05:51 PM Thread Starter
gbhs72's Avatar
This is exactly what I have thought on this. Thanks a ton.
Bob, right now I'm looking at the grass outside and thinking I'll be mowing it in about a week. Rain this week end but it's getting green and shaggy.
Mark: Snowman-33
gbhs72 is offline
post #8 of 9 (permalink) Old 02-24-2019, 02:06 PM
Quoting myself IKR. Well, the problem with getting old is you do something pretty smart -- and then forget about it. It turns out when discovering the leaking drain that I had emptied the AF to salvage it (it's fresh from my latest re-re-built opti install). So, the experiment was not applicable anyway. Interesting simple design as it comes out by just clocking at half its rotation and pull out. A little dielectric grease and the new one just about installed itself. I know not thread related, just interesting in a pesky detail sort of way.
post #9 of 9 (permalink) Old 02-24-2019, 03:52 PM Thread Starter
gbhs72's Avatar
Tis Okie. I know how conversations wonder. Sometimes makes things more interesting.
Mark: Snowman-33
gbhs72 is offline
Similar Threads
Ovalized trailing arm mounting holes Big Jack Suspension 9 09-11-2018 07:43 AM
Clean your quarter panel drain holes!!!! GN 1220 Wagons 6 03-18-2008 09:10 AM
95 9c1 control arm EPBLVDM Caprice 1 09-09-2007 10:05 AM
95 9c1 Control Arm EPBLVDM Caprice 0 09-08-2007 04:18 PM
Recommendations for rear control arm bushings? Moparman Suspension 2 08-21-2007 04:11 PM
