Front shock absorber top bolt - Chevy Impala SS Forum
 1Likes
post #1 of 17 (permalink) Old 02-25-2019, 04:19 PM Thread Starter
cadejohnson58's Avatar
I tried using pb blaster on the top single bolt and bottom two bolts. The two came out fine, but the top is spinning the bolt with the silver mini shaft. Am I not seeing a allen bolt on top of the shaft? I tried medium and large vice grips did it as hard as i can im strong and it was still spinning please help i put it all together so no rush.
cadejohnson58 is offline
post #2 of 17 (permalink) Old 02-25-2019, 04:41 PM
KingsKrew's Avatar
KingsKrew is offline
post #3 of 17 (permalink) Old 02-25-2019, 05:17 PM Thread Starter
thank you so much
post #4 of 17 (permalink) Old 02-25-2019, 05:39 PM
I have always used vice grips on the shock rod to hold it....since the shock was being replaced
j cat likes this.
post #5 of 17 (permalink) Old 02-26-2019, 09:01 AM
angelo's Avatar
Glad yours went easier than mine..... I was ready to shoot myself....SMH
https://www.impalassforum.com/vBulle...bilsteins.html
-ALF out...
ECIRS #427 ISSCA #01978
CLICK ME !!!
angelo is offline
post #6 of 17 (permalink) Old 02-26-2019, 10:18 AM Thread Starter
-ALF out...
everything under this car is 20+ years old im the second owner so its hard to break a bolt free especially if you wanna keep that bolt. I was looking for the allen head on top of the piston shaft cause i knew a vice grip couldnt hold something with no indent, just kept spinning. Im thinking cut off wheel or dremmel if shes gonna play hard to get. I went to your thread, i would like to buy new quality bolts as well since im down there. Im thinking the rears will be twice as hard cause its far up and the spring is in your arm reach i think. Thanks all you guys.
post #7 of 17 (permalink) Old 02-26-2019, 10:19 AM Thread Starter
thanks BALLSS i was doing the same, didnt want it to come to cutting it out but I'm not sweating it. I live in Ventura CA i see you live in Moorpark
post #8 of 17 (permalink) Old 02-26-2019, 06:00 PM
The rears are tough to get but I never found them as difficult to do as others have reported. I got BIG hands so that does not help. But I either had a box/open end wrench that I finagled from the top to secure it while I used a long extension and socket to undo the bolt from below.
I really don't remember them causing me too much grief. If you are concerned though, reach out to Bill (member - NavyLifer) as he sells a nice little Kit which uses as I would describe as a "U" shaped bolt that drops in place and nuts go on from below...nothing to have to keep from spinning above.
post #9 of 17 (permalink) Old 04-21-2019, 03:03 PM Thread Starter
This front passenger shock is still baffling, does 2 vice grips help? I was thinking of getting a file and just get one side of the still spinning piston shaft so my vice grips stops slipping. Cause i need a socket up top i dont see how people do vice grips up top and a open end wrench together. This jobs a pain to do without cutting it with fire or air chisel which I dont have.
post #10 of 17 (permalink) Old 04-21-2019, 04:34 PM
My word. If everything in Kings-' link did not work then salvage your sanity and run it to a muffler shop and for ~$30 get them to torch it.
Similar Threads
Strut / Shock Absorber Rebates RockAuto RockAuto 1 11-15-2015 07:59 PM
Shock absorber (upper nut stuck) Iamduval Suspension 9 04-15-2011 03:57 PM
Bilstein AK1053 front shock absorber Navy Lifer Suspension 64 07-30-2009 04:23 PM
Bumper Energy Absorber Question nauglrj Drivetrain 10 09-27-2008 10:21 AM
"The Absorber" On Sale 7.99 At Kragen's banker Exterior 2 03-28-2002 06:13 PM
