What size nut is the high-pressure line that goes into the steering gearbox? - Chevy Impala SS Forum
 2Likes
  • 1 Post By Blue Wail
  • 1 Post By 95wagon
post #1 of 9 (permalink) Old 03-26-2019, 09:38 PM Thread Starter
I inadvertently slightly buggered the first thread on the bolt on the high pressure power steering hose, so that it won't seat quite right and screw into the steering gearbox. (Yeah, my fault. I have R&Red a half dozen or so steering gearboxes on this car without screwing it up, so apparently the sixth time is the charm.)
Before I go spending $50 on a new hose (and this one is literally almost brand new), I'm going to get a grade 8 nut and force thread it onto the bolt to clean up the threads. (The steering gear is fine--I was able to screw in the plug no problem, although I no longer have it so I can't take it to the hardware store to match it up to a nut.)
As far as I can tell, it's an 18mm bolt, so does that mean that an M18 nut would work? Coarse thread, I presume? Thanks.
--'94 Caprice "SS" wagon, 0.30 over, high-volume oil pump, LT4 hot cam, 1.6:1 rockers, ported aluminum Corvette heads, shorty headers, PCM4Less tune, 4.10s, shift kit, side-exit dual exhaust with Flowmasters, OR X-pipe, F-body gauge cluster, Bonneville front and rear seats (working electrics), Bravada console shifter, Bilsteins, 12.7:1 Impala steering box, Boss 338s with 255/45R20s, bunch of other stuff I'm forgetting.
--'04 Mustang Cobra, '15 Audi S4
--1125R, 1050, VMax, VFR800, DRZ-400E
TheFleshRocket is offline
post #2 of 9 (permalink) Old 03-27-2019, 01:04 AM
gbhs72's Avatar
Flesh, If it's 18 MM how about something like this? https://www.summitracing.com/parts/p...1690/overview/ YOu should be able to get one locally though. I have a set of SAE thread chasers and will get a metric set too.
Well shoot, I read what you wrote and I missed that it was the fitting on the hose. My thought is to get an inexpensive tap & die set. Think HF. I would do that before using a nut to clean it up.
Mark: Snowman-33
gbhs72 is offline
post #3 of 9 (permalink) Old 03-27-2019, 07:31 AM
The head is 18mm, but the threads are somewhat smaller. I do not know the thread size or pitch.
post #4 of 9 (permalink) Old 03-27-2019, 07:32 AM
babywag's Avatar
I always had good luck using a very small file.
Got several just for stuff like this.
Works well.
babywag is offline
post #5 of 9 (permalink) Old 03-27-2019, 08:22 AM
Blue Wail's Avatar
Do yourself a favor and get a NEW high pressure line from rock auto.
They're only like $20. C'mon man!
https://www.rockauto.com/en/catalog/...sure+hose,7320
Nab
gbhs72 likes this.
April's Sparkle Cat
383 LT1 12:1 flat top + 75 shot
11.66 @ 117 at SSHS17 Nov 11, 2017
2017 12.0 Index Champion
4140 lbs. w/ driver. front sway bar ON
Powered by 4L80E! (controlled by LT1 pcm)
Blue Wail is offline
post #6 of 9 (permalink) Old 03-29-2019, 12:28 AM Thread Starter
This IS an almost-brand-new hose, and it's the AC Delco one. More like $40 shipped.
Anyway, I got it resolved. I put several loops of teflon tape on the threads and that was enough to get them to bite so I could get the bolt screwed in.
It is M18, and it's fine thread. Not sure what pitch, but it's definitely less than 2.50. I couldn't find an M18 fine thread nut locally.
post #7 of 9 (permalink) Old 03-29-2019, 06:52 AM
Blue Wail's Avatar
AC Delco means nothing. Its just rebranded from China like everything else
with 50% markup to make you feel special!
Anyway, I hope your jimmy rig stays leak free!
Nab
post #8 of 9 (permalink) Old 03-29-2019, 11:22 AM
95wagon's Avatar
For what it is worth the steering box thread sizes are
M18 - 1.5 , M16-1.5
TheFleshRocket likes this.
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
11.79 @ 120.65
LS7 T56 drag video
My Wagon
My W-31 Cutlass
95wagon is offline
post #9 of 9 (permalink) Old 03-29-2019, 12:21 PM Thread Starter
Nab
I don't think that AC Delco stuff is necessarily rebranded Chinese junk. My wagon kept blowing one of its AC lines and my mechanic at the time kept replacing them with whatever cheapy made in China hose he could find. I finally replaced it with an AC Delco line and it's been solid for years.
Same thing with the alternator--I went through 3 or 4 Remy lifetime warranty units from Rock Auto, all of which had various issues (and each one had a different issue). I then bought an AC Delco, which looked identical down to the stickers, but which has worked flawlessly for 20K miles or so. I suspect it came from the same factory, but just tested "better" than the units that got badged as Remys.
Similar Threads
temp needle goes into red and stays, but goes down if i turn car off then on Kilgore Engine Problems/Maintenance 8 02-07-2017 05:21 PM
Power Steering Pressure Line Size Issue THRSSTY Suspension 1 08-24-2008 10:49 AM
F/S: AGR Billet steering gearbox - Like new in box! scoob8000 Parts for sale/wanted 10 06-04-2008 06:17 PM
Anyone around PA have a (rear) LCA bolt/ nut and a UCA nut? tylert14 Parts for sale/wanted 4 02-12-2007 07:52 AM
Car goes into closed loop, stumbles, runs bad off the line liljiggaboy Engine Problems/Maintenance 5 11-10-2005 04:55 AM
