Power steering pump leaking from shaft area? - Chevy Impala SS Forum
post #1 of 1 (permalink) Old 04-21-2019, 09:20 AM Thread Starter
A few months back, I replaced the power steering pump with a remanufactured unit (pretty sure it's an Endurance reman from Autozone), the hoses, and had my steering gear box gone over by Lee Manufacturing. Since then, I have since had a power steering fluid leak. The leak is initially visible dripping from the bottom of the AC compressor onto the PS lines below it.
The lines connected to the reservoir are dry, so the leak's not coming from there. The connections where the high pressure line and the reservoir hose attach to the PS pump are also dry. I can't see the front of the PS pump as it's hidden behind the pulley, but I suspect that's where the leak is coming from. As far as I know, there's no where else in that vicinity for a leak to come from. I figured I'd see if you guys concurred before I started pulling stuff apart to see the front of the PS pump.
--'94 Caprice "SS" wagon, 0.30 over, high-volume oil pump, LT4 hot cam, 1.6:1 rockers, ported aluminum Corvette heads, shorty headers, PCM4Less tune, 4.10s, shift kit, side-exit dual exhaust with Flowmasters, OR X-pipe, F-body gauge cluster, Bonneville front and rear seats (working electrics), Bravada console shifter, Bilsteins, 12.7:1 Impala steering box, Boss 338s with 255/45R20s, bunch of other stuff I'm forgetting.
--'04 Mustang Cobra, '15 Audi S4
--1125R, 1050, VMax, VFR800, DRZ-400E
TheFleshRocket is offline
Similar Threads
Power Steering box leaking the blur Suspension 4 02-12-2012 06:45 PM
whining/squealing sound from power steering pump area 94SSuperSSport Engine Problems/Maintenance 2 05-01-2011 06:41 AM
What part is this leaking power steering fluid, pics inside BYB_CUZ Engine Problems/Maintenance 9 02-24-2010 09:26 PM
power steering leaking SSLVER Engine Problems/Maintenance 1 01-03-2006 10:38 PM
Intermediate Shaft (steering shaft). aslitti Suspension 1 09-20-2003 10:52 PM
