Rear axle limit straps... (no spring fall out) - Chevy Impala SS Forum
post #1 of 13 (permalink) Old 07-21-2019, 07:46 PM Thread Starter
1994 Caprice LT1 Wagon
Threw on some rear drop springs...
Belltech 2.75 drop.
Now my springs fall out if I Jack it up, or hit a crazy bump...
Fabbed some 10" rear axle limit straps from rear seat belts from a Chrysler 300..
Had my lovely wife sew them on her badass sewing machine...
Drilled some holes in the axle perches, and mounted them up.
Also running belltech nitro 2 drop shocks, energy suspension bushings, and extended my rear LCA and UCA 1/2"...
Check it out.
Alpha_numeric44 is offline
post #2 of 13 (permalink) Old 07-21-2019, 09:19 PM
gbhs72's Avatar
Well now. That is a new and interesting one to me. The idea of using zip ties, while fast & easy, never appealed to me. I may have to put one of my Consews to work again. We need more pics of your car. That is if you're done painting. It sort of has a PoPo look to it.
Mark: Snowman-33
gbhs72 is offline
post #3 of 13 (permalink) Old 07-22-2019, 08:29 PM
Sshockr's Avatar
I just bolted the springs to the lower perch, but those look pretty good. I know a lot of off-road shops sell those if you don't have spare seatbelts handy.
-Brian
'95 B4U LT1/T56 in Purple Pearl. 24x 355 with I believe most of the bolt-ons.
'63 C10 LT1/4L60E from B-Body. Rides like a Cadillac thanks to air bags.
'06 GTO LS2/T56 Torrid Red with CAI and Borla Cat-back thanks to the lady who rear ended me.
Still in Wichita.
Sshockr is offline
post #4 of 13 (permalink) Old 07-23-2019, 12:59 PM
Hi
Oldhead here......Are you sure the shock don't control limit ????
95 WAGON.SS wheels,Exhaust straight out the back.Extra bright cargo lights.Virgin ashtrays,Copper battery term.32# in tires
oldhead is offline
post #5 of 13 (permalink) Old 07-23-2019, 01:39 PM Thread Starter
I'm running belltech nitro 2 drop shocks and belltech 2.75 drop springs.
The springs fall out when jacked up.
This prevents it with just enough room to get the 20" wheel off and out of the wheelwell.
post #6 of 13 (permalink) Old 07-24-2019, 07:20 AM
91ss's Avatar
Would you know or can measure if you get a chance, what the free length of spring is? Oh, and what the extended length of those shocks is, Thanks
91ss is offline
post #7 of 13 (permalink) Old 07-24-2019, 07:41 AM
I have been told that there are drop springs that will not fall out. I have the ones that will fall out, so I welded a couple of pieces of exhaust pipe (about 3 inches) to the top perches, and zip tied the spring to the lower ones. They do not fall out, and I have enough room to get Impala rims with 255s on them out with full extension.
I have drop shocks, "adjusted" drop springs, and drop spindles on the front, and I can jack the whole side of the car from the rear jacking point to facilitate changing both tires on one side.
Fred Kiehl is online now
post #8 of 13 (permalink) Old 07-24-2019, 02:02 PM Thread Starter
The part numbers are 8512 for the rear shocks and 8000 for the front.
The belltech website probably has the info you want... or just call and ask. They were quite knowledgeable when I called.
post #9 of 13 (permalink) Old 07-27-2019, 09:13 AM
Sinister's Avatar
Moog CC501 fit perfectly in the rear and do not fall out when you jack up the car. Lowers the wagon perfectly. 50 bucks well spent.
1995 Caprice Wagon
Sinister is offline
post #10 of 13 (permalink) Old 07-27-2019, 11:15 PM
95wagon's Avatar
Yup,, been in my car since 2002ish.
I dont like a car quite that low so i also have 1 inch spacers on top so mine are even more preloaded,at full droop
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
11.79 @ 120.65
LS7 T56 drag video
My Wagon
My W-31 Cutlass
95wagon is offline
