Is my idler arm bad??? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 09-12-2004, 09:20 PM
efingstein
I'm getting a shimmy on my 93 1a2 that starts at low speeds and builds to about 45 then stops. The steering is a little less responsive that normal. If the car is sitting on the ground, I can kick either tire and see a deflection in the idler arm. What's the symptoms for a bad idler?
post #2 of 4 (permalink) Old 09-13-2004, 07:49 AM
Knaagi_II
Hi,
Watch the idler arm when you joggle one of the front tires, -or let someone move the steering wheel a bit. When the idler arm is moven up and down instead of left and right, itīs worn.
For the shimmy I would get the wheels balanced also.
post #3 of 4 (permalink) Old 09-13-2004, 08:31 AM
95wagon
While you could have a worn idler as well, I am willing to bet you have a cord-belt issue in one of your tires.
It has been my experience that a low speed wobble or shimmy that goes away as speed rises is almost always tires.
Jack the car up and spin the tires. In extreme cases you can see the tread squirm.
Gerry
post #4 of 4 (permalink) Old 09-13-2004, 10:06 AM
efingstein
Thanks everybody. I'll let my mechanic friend look at it this afternoon when I head over to his shop to work on my other car.
