Is alignment change needed ?? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 08-28-2004, 07:30 AM
foxout72
Installed 255/50/17 on 9.5 rims 94RMW..Do I need to change the factory alignment...If so can someone provide specs....
post #2 of 4 (permalink) Old 08-28-2004, 07:45 AM
CHV_FRK
Nope, not as long as your alignment was in spec prior to the change. Only changes that change spindle to body relationship would require an alignment.. ie, spring change. Now there are more aggressive alignment specs out there that make our cars handle better. You can find that through the search.
post #3 of 4 (permalink) Old 08-28-2004, 07:53 AM
bengston
If you are saying the car has not been aligned since the factory, I'd suggest at least getting it checked.
Here's some specs;
https://impalassforum.com/cgi-bin/ult...&f=16&t=003561
A search will reveal a few others...
post #4 of 4 (permalink) Old 08-28-2004, 07:59 PM
95wagon
Sorry I disagree.
Any noticeable change in wheel offset will change the ride height subtly, which will effect the alignment
Gerry
