drop problems?? - Chevy Impala SS Forum
post #1 of 19 (permalink) Old 08-04-2004, 05:37 PM
BADwayz
I recently lowered my SS with 2" Sprint springs and I noticed that the rear pass. side tire (stock wheels and tires) was rubbing on the inner fender well. When I looked closer, the pass. wheel is about a 1/2" closer to the fender well than the drivers side. I have no idea what to check or do about it, any ideas? I dont remember if it was like this before the drop because it wasnt an issue until now.
post #2 of 19 (permalink) Old 08-05-2004, 06:08 AM
wkeil
Check this post out. Here
post #3 of 19 (permalink) Old 08-05-2004, 10:01 AM
louich007
So its would maybe be the spring that are not properly fixed or bad body bushings.
post #4 of 19 (permalink) Old 08-05-2004, 03:33 PM
BADwayz
Im sorry, i didn't specify enough. My drop height is perfect all around, but my whole rear end is moved over to the passenger side about 1/4 inch causing my pass wheel to rub although I can fit my fingers into the wheel well of my drivers side rear.
post #5 of 19 (permalink) Old 08-05-2004, 03:50 PM
camel
from my understand thats a regular problem, my axel is also about 1/4 closer to the passenger side. but since i have a 9c1 my axel is a bit narrower then yours and i don't have any rubbing problems with my intrax springs. is it hitting the fender or the trim?
post #6 of 19 (permalink) Old 08-05-2004, 03:54 PM
BADwayz
it was hitting the trim, but i cut the lip off of it last night and now it isn't rubbing anymore....but the fit is so tight, the only thing i can get between the wheel and the wheel well is a butter-knife.
post #7 of 19 (permalink) Old 08-05-2004, 08:33 PM
signguy
From my experience with "b bodies" the rearend is never centered one way or the other.I dunno why though....
post #8 of 19 (permalink) Old 08-07-2004, 03:10 AM
BADwayz
is this going to cause any long term problems? and is there a simple way to fix this?
post #9 of 19 (permalink) Old 08-07-2004, 07:26 PM
wkeil
What other parts were replaced besides the springs?
post #10 of 19 (permalink) Old 08-07-2004, 09:30 PM
BADwayz
nothing else, just springs.
