Something is wrong! - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 08-18-2004, 07:47 AM
Mitchell
Angry
There is a swaying motion in my cars rear end. the faster it goes the worse it gets. I have only had my Imp. for about a year. Not sure if there are sway bars or what in the rear end. Any sugestions would help. Thank you!!
Mitchell 96 Imp. SS
post #2 of 5 (permalink) Old 08-18-2004, 11:33 AM
CHV_FRK
Quick idea would be to take it to a shop that will give you a free estimate. Act dumb, at least a little, and that will give you a place to start.
Otherwise just jack the car up and check all nuts and bolts for tightness, and visually look at the condtion of the bushings.
post #3 of 5 (permalink) Old 08-18-2004, 05:00 PM
LarryCigar
Arrow
Eyeball all Rear Control Arms & Bushings.
Also hold down bolts on Sway Bar.
post #4 of 5 (permalink) Old 08-20-2004, 11:51 PM
maxwellc
You might also just check tire pressure. I can think of at least two times when I thought..."Whoa, somethings wrong this car is really squirrely in the back end." and it turned out to be low tire pressure. Hopefully it's something easy like that.
Sean
post #5 of 5 (permalink) Old 08-21-2004, 01:30 AM
95wagon
If it is doing this also at slow speeds in a straight line you may thrown a belt in a tire.
Jack the car up and spin the rear tires while watching the treads.
Just one more idea to add to the good possibilities posted already.
Gerry
