Rattling suspension... - Chevy Impala SS Forum
post #1 of 14 (permalink) Old 08-07-2004, 10:27 PM
MUSCLE9C1
Angry
Alright i dont know what to do now i've checked everything i can think of but theres still that stupid rattle its drivin me crazy! What could be the problem? every time i hit the slightest bump you can hear it rattling and it so loud i can almost hear it over my exhaust.... I tightend the front SB bushings again, i just replaced them about 4 months ago, and it still wont go away. What could be the problem? any ideas or anything would be very helpfull. Thanks
post #2 of 14 (permalink) Old 08-07-2004, 11:46 PM
Knaagi_II
Are you sure itīs from the front end?
Do you hear it only when your driverīs window is open? If yes, try to hit a bump with applying the brakes. When the rattling stops with braking itīs just this brake pad issue and you just have to bend the "ears" of the outer brake pads.
post #3 of 14 (permalink) Old 08-07-2004, 11:50 PM
MUSCLE9C1
Arrow
Im very positive its from the front end. not the brakes cause i just changed the pads a month ago, it just bugs me... Oh ya you shouldnt bend the wear indicators on the pads man bad idea just ask my buddy
post #4 of 14 (permalink) Old 08-08-2004, 12:43 AM
Knaagi_II
So you already tryīd it with braking on a bump?
I think i didīnt mean the indicator. When you have new pads installed and the caliper mounted, the outer pads have these two ears. One at the top, one below. Are these meant to be indicators?
Both have to been bend till thereīs no play and the pad is sitting tight. Thatīs how itīs written in the Haynes manual.
I mean this:
https://impalassforum.com/cgi-bin/ult...;f=23;t=000114
post #5 of 14 (permalink) Old 08-09-2004, 12:45 AM
MUSCLE9C1
the rattle is still there even when hitting the brakes and hitting a bump. so im so lost on what i should do to fix the problem.
post #6 of 14 (permalink) Old 08-09-2004, 06:04 AM
wkeil
I have the same problem. Did you check exhaust hangers?
post #7 of 14 (permalink) Old 08-09-2004, 07:13 AM
Lynden
Not sure if this would pertain to your case, but I thought I had a rattle in my front end for a while, then I realized that it was my center caps rattling when I would hit bumps. Might check your center caps on your wheels.
post #8 of 14 (permalink) Old 08-09-2004, 10:21 AM
reverendstu
FWIW, on my old car, the mystery rattle was the bolts that hold the cross member to the tranny backed out a good bit, it rattled every bump. Well, more of a clunk really.
post #9 of 14 (permalink) Old 08-09-2004, 05:46 PM
Navy Lifer
I'll say this enough and eventually may not have to repeat it. For now, the broken record still plays....
Last work done--changed pads?
What else did you do?
What else did you not do that you should have?
We don't have enough info, but.....
I'm going to suggest that you need to check the bushings (yes, they do exist) in the front calipers. Their job is to allow free movement of the calipers (ie. float) while providing noise isolation by avoiding metal-to-metal contact between the caliper slide pins/sleeves.
If all you did was replace the pads, there is a chance the bushings are in need of replacement as well, and under certain conditions there is the presence of noise from the caliper housing's contact on the sleeve(s).
GM caliper service kit 18005606--enough parts and lube for both front calipers.
post #10 of 14 (permalink) Old 08-09-2004, 05:56 PM
atlSS96
Another thing to check would be your body bushings. If they are degraded enough, the washer on the retaining bolt(s) may be rattling. I know my SS when I first bought it ( thanks GM for the foreward bushing delete from the factory ) had a simillar rattle, upgraded to the 9C1 bushings and all was well
HTH, Scott
