ST Rear Spring Questions - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 02-18-2004, 02:20 AM
SSlumpin Imp
I was wondering if these were the same as sprints.
Sprint Springs
Front: 485 lb/in
Rear: 285 lb/in
ST
Front: 533lb/in.
Rear: 272lb/in.
These are the spring ratings that i've found so they i think they're different but i've heard they are one in the same. How about the drop for the rears? also wanna know about the fronts. Thanks
post #2 of 3 (permalink) Old 02-18-2004, 02:24 AM
SSlumpin Imp
Also, would these work well in my setup? Stock front springs and these in the rear.
Stock SS Springs
Front: 444 lb/in
ST
Rear: 272lb/in.
Stance thoughts? with my 2" drop spindles?
I should be getting my shocks this monday
Just thought i would let everyone know!
post #3 of 3 (permalink) Old 02-18-2004, 12:48 PM
They'll work fine. However, the STs point out the usual issue of drop springs on these cars : they don't go high enough in rate!
Increasing the front spring rate to 650-750 lbs/in makes a noticable difference in handling, while NOT influencing the ride all that much!
On the other hand, even small (i.e. 10%) changes in REAR spring rate do noticably affect ride quality. With the ST rear springs (270 lb/in vs stock 160 lb/in rate), expect the ride to get considerably stiffer. Also expect it to become more difficult to get the car to hook up off the line. Unfortunately, with drop springs in back you're pretty much stuck with the higher rates to avoid bottoming out the suspension even if the rates aren't ideal from a ride or handling standpoint.
