Noise from rear pass. wheel (or so it seems) - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 08-14-2003, 11:23 PM
Chevy350
I have a noise coming from the rear of the car, sounds as if the wheel is bouncing up and down. I have bilstien shocks, and new bushings. Is it possible that the the shocks are to hard? or bad shock? I have checked all the other bolts, everything is tight. I was thinking if it could be the fuel tank that might be loose on that side but it seems tight. does anyone else have this problem?
post #2 of 2 (permalink) Old 08-18-2003, 12:35 PM
sephirothq
I had a clunking issue with my rear tires, I thought it was the rear at least. I replaced the caliper and the nosie isn't as bad as it was before. I don't know if this helps or not
