left wheel squeak - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 07-15-2004, 04:37 PM
95SuperSport
hopefully this is an easy answer... when i make a left turn the left front wheel makes a consistently and repetitive squeaking sound. its always happened just finally thought to put it up here. I did just rotate the tires, however, and it still does it...thanks for any help
post #2 of 4 (permalink) Old 07-15-2004, 04:44 PM
vandal835
Is it a tire squeak? How sharp of a turn where you making?
Is it a belt squeak? The water pump could be leaking on the belt beauce an extra load is put on the belt while PS pump while turning.
High pitched squeak? When where the brakes last checked?
I have a squeak like that on the right wheel.. And not the left wheel also on my 95 SS.
I think this is being caused by bad wheel bearings and worn pads. Monday I get my parts!
post #3 of 4 (permalink) Old 07-17-2004, 09:16 PM
95SuperSport
Its not from cornering too hard or braking. It just squeaks when I turn left above 20 mph.
post #4 of 4 (permalink) Old 07-17-2004, 09:17 PM
95SuperSport
water pump is 1 year old too and no signs of leaks....maybe the bearings??
