balljoint - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 08-07-2004, 06:06 AM
show-boat
Does anyone know of a replacement lower balljoint tha has the same tapper as the stock lowers in a caprice or impala but instead of press in has bolt holes like the upper balljoints?
post #2 of 4 (permalink) Old 08-07-2004, 11:14 AM
It doesn't exist
post #3 of 4 (permalink) Old 08-07-2004, 11:21 AM
Rustic
Even if it did exist... where would you bolt it in on the stock lower arm???
There are thread-in lower ball joints that were made for Chrysler products.... but again, our stock arms would need heavy mods...cutting and welding... to make that happen.
I went through all of this working on my tubular front arm project... and it really seems like the press-in isn't a bad way to go. Especially if you want to keep eveything compatible.
post #4 of 4 (permalink) Old 08-07-2004, 01:10 PM
show-boat
there not for stock arms there for tubular im building
just wanted to see if there was other options
i could mill out the spindle and get a sleeve made and pressed in to change the tapper in the hole
