Install new rear UCA bushings or no? - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 07-31-2004, 07:00 PM
CMoney
I have my rear end dropped ready to put in all the new suspension components. I have Kaotic uppers and lowers with poly bushings, Hotchkis springs and QA1's. Now, for the UCA to axle bushings, should I attempt to install poly ones of leave the stock rubber ones in place? The shells are rusted to the axle so removal would be a pain but otherwise the bushings look in decent shape. Am I risking anything here by leaving the stock rubber bushings at one end? Will they deteriorate pretty quickly?
post #2 of 3 (permalink) Old 07-31-2004, 09:59 PM
jayoldschool
I left the stock rubber bushings on the diff. They looked great - brand new compared to the ones on the arms...I have had no problems.
post #3 of 3 (permalink) Old 08-03-2004, 01:45 AM
roady94
- The last time I checked (6-7 weeks) the most popular choice was to keep OEM bushings in the rear UCA's. There is a bunch of info on this that does not need repeating here.
Even if your UCA busings look "in decent shape", if they are original, they are 9-10 years old and must be well along in their lifespan. For the relatively inexpensive cost of replacements and the opportunity to do the work with the axle already dropped, I don't see how you could not replace these now.
-Jay
