96 Caprice Classic to SS Suspension - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 03-03-2004, 12:40 PM
gdh11
I have a 96 Caprice Classic and am converting it to as close as I can get SS. What mods do I need to make to get the rims to fit and the suspension to the point of being close to an original SS? In particular will the original SS rims bolt up and fit that body without mods? Do I need to lower it, if so how much? Is the steering gear box different? Thanks
post #2 of 11 (permalink) Old 03-03-2004, 12:47 PM
4DRVETE
sent pm
post #3 of 11 (permalink) Old 03-03-2004, 01:23 PM
darius
GW9C1,
Can you send me a PM also, I would like to see the answers to the same questions.
regards
post #4 of 11 (permalink) Old 03-03-2004, 01:36 PM
buffman
the rims will bolt right up..
matt
post #5 of 11 (permalink) Old 03-04-2004, 08:05 AM
gdh11
Can anyone tell me if there is anything different on the suspension between the two cars? Springs, front end, gear box, etc? Thanks
post #6 of 11 (permalink) Old 03-04-2004, 08:15 AM
RJI
The springs and shocks are different. The sway bars are the same.
Check you SPID lable in the trunk and see what the code is for the suspension. Sport suspension or Trailer tow package will have the same steering box as the SS.
The SS wheels will fit perfectly.
post #7 of 11 (permalink) Old 03-04-2004, 08:18 AM
Mike454SS
The differences from the factory are the springs and shocks.
The rest applies to 94-96 cars.
Is your car a civilian caprice or a police package 9C1 caprice? All of them have the same front brakes as the SS, but only the 9C1 will have the rear discs that the SS got as well, a civilian car will have rear drums. A 9C1 rear axle is slightly narrower, but SS rims will still bolt right on to it. The car won't look "right" without spacers to push the wheels out slightly, park a 9C1 on SS rims next to an SS and you will see what I mean.
A civilian caprice might not have the same swaybars as an SS does, but a 9C1 will. Either way, ALL the SS/9C1 parts will bolt on.
Also, a 9C1 and an SS both have "fast" ratio steering, I believe it is 12.8:1. A civilian caprice will have a slower ratio steering gear and thus the steering wheel needs to turn further to make the car turn the same radius corner.
post #8 of 11 (permalink) Old 03-04-2004, 01:14 PM
gdh11
454SS,
It has rear drums and I think it has the towing package and sport suspension. So from what I get from the info is that I need to change springs and shocks, is that correct?
post #9 of 11 (permalink) Old 03-04-2004, 09:06 PM
RJI
454SS,
That should take care of it.
post #10 of 11 (permalink) Old 03-05-2004, 06:50 PM
gdh11
Thanks
