Choosing stiff rear springs that lower - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 03-12-2002, 06:38 PM
kevm14
The goal for my 9C1 is to end up lowered, maybe about stock SS height, but be more stiffly sprung than a stock SS. I have determined that cutting my 9C1 springs on the front will leave me with the desired stiffness and height, but the rear poses more of a challenge. You can't just cut them, or it's highly discouraged. So I am curious what's out there for aftermarket support that has a stiffer spring rate than my stock 9C1 rear springs. I don't think SS springs will be stiff enough, though with a beefier sway bar, I could probably counteract that softness.
Among brands to consider:
ST
H&R
Sprint
Eibach
There may be others, but I am interested in the available heights and spring rates. Does anybody at least know what my 9C1 rear springs are for spring rate? That way I can call around and ask for spring rate information. I figure I should first determine the new rate of the front, then find a new rear spring rate that is proportionally greater.
Thanks for the help (and sorry if this has been covered before - I'll make use of the search function also)
post #2 of 3 (permalink) Old 03-12-2002, 06:54 PM
PaulD
Hey Kev,
I have the stock 9C1 front springs cut by 3/4 coil and SS springs in the rear. If you can wait until 4/27 at NED, if you're planning on coming, you can check the height and take it out for a spin. [img]smile.gif[/img]
I can't tell you about aftermarket springs. Didn't need to go there.
post #3 of 3 (permalink) Old 03-12-2002, 07:12 PM
kevm14
Wow, that would be most helpful...not sure what I am doing on April 27th. That is the last weekend before finals but I'll see what I can do...also, I may also be forced with deciding between NED and Dyno Day with UNYISSO. I am tempted to go to NED instead, however. I won't know what to do with myself with another 93 9C1 around!
