Drag racing with airbags - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 09-10-2004, 08:50 PM
FleetwoodSS
Anyone have any pointers for height configurations when it comes to racing at the track? Put the rear up higher? Maybe front higher? All the way up?
post #2 of 6 (permalink) Old 09-10-2004, 09:58 PM
northstar_v8
Front all the way up and rear all the way down...
You probably won't run a 10, but you can look like you will [img]graemlins/.gif[/img]
post #3 of 6 (permalink) Old 09-11-2004, 12:30 PM
tbsimmons
When I had bags in my Mitsubishi minitruck, and I raced Hondas. I know a jap racing more jap crap. But i had a cam, headers, no cats and some head work. It would keep up with the EX Civics.
Anyways, I would let the back almost all the way down, not all the way because my roll pan would drag, truck was body dropped also. Just enough that the back would dip and nothing would drag. The front I would lift a little higher, not all the way, but higher than the back. It worked pretty good. That was a truck with no weight in the back either. SHould work better with a big sled like a Cad.
post #4 of 6 (permalink) Old 09-11-2004, 09:48 PM
SSoMad
Sometimes it's good to keep a little more air in your right rear than left.
post #5 of 6 (permalink) Old 09-15-2004, 01:01 PM
twbelieves
Concensus seems to be 19lbs in right rear and 8 lbs in left rear.
post #6 of 6 (permalink) Old 09-15-2004, 02:18 PM
pgish
TomSS' suggestion of 19 lbs for a 1.80 60' sounds about right, maybe a little low from my experience. The harder your car is capable of launching, the more body twist, and the more differential pressure you need. 30lbs in my right bag and almost nothing in the left was good for a straight 1.63 60' with a dead posi.
Here's how I "tuned" the bag on NA launches:
Launched with hands off the wheel. If the car headed right, that told me I needed more air in the right bag. You might be surprised at how much you really need. When it's correct, there should be very little posi action required.
