60' Time and UCA ? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 09-17-2004, 12:07 PM
S1996S
Anyone noted a "measureable" change in 60' times after installing rear UCA's. This would be in addition to haveing LCA's.
TIA
Roger
post #2 of 4 (permalink) Old 09-17-2004, 12:16 PM
Klez
Since we are on this topic how about LCAs stock length or extended?
post #3 of 4 (permalink) Old 09-17-2004, 12:19 PM
As far as a straight swap, I wouldn't expect much.
With them adjustable, you can adjust pinion angle to get more "bite" and help 60 ft times. Note this more aggressive pinion angle probably isn't gonna help your U-joint life.
All else being equal, a car with extendeds will be slower than the same car with stock length. Geometry gets worse, and weight distribution gets worse (i.e. more front heavy) with the extendeds.
post #4 of 4 (permalink) Old 09-17-2004, 01:04 PM
S1996S
By "measureable" going from OEM to aftermarket I was hopeing for .03 or more improvement in 60'.
With that said the Hotchkis LCA's I have on are superior to OEM lowers. Now I am adding the uppers to finish out my suspension.
