Help Please! - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 02-20-2004, 05:56 PM
JimmieSS
Cant stop inside tire wear. Alignment is straight, moog everything, and bad left front bearings changed. Could there be something in the rear causing this?
post #2 of 7 (permalink) Old 02-20-2004, 06:25 PM
BadNewsSS
i'd be willing to say, most likely not, did you do the alingment, or no? if you had a shop do it, you might want to take it somewhere else and have them check, have you checked tire pressure?
post #3 of 7 (permalink) Old 02-20-2004, 07:12 PM
JimmieSS
Alignment was done by Firestone
post #4 of 7 (permalink) Old 02-20-2004, 09:11 PM
uncle hulka
JimmieSS, gotta suspect alignment, especially
camber... Are you lowered at all?
post #5 of 7 (permalink) Old 02-20-2004, 11:34 PM
JimmieSS
Yes, Hotchkis and Bilstien all the way around.
post #6 of 7 (permalink) Old 02-20-2004, 11:47 PM
cadave
ok you need to find a good alignemnt shop in your area one better than firestone i just dont trust those guys. look in the phone book you will find a good alignment shop and i bet your problems will hopefully be solved or at least someone more quailfied than firestone techs will look at your ride and get it set right.
post #7 of 7 (permalink) Old 02-21-2004, 10:17 AM
uncle hulka
Jimmie, just got out of work, sorry. With the
lower springs you will probably need offset
cross-shafts on the upper arms to allow enough
shims to effectively adjust camber. I did!
I'm guessing the alignment shop may have settled
for what they could get.
