campaign questions - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 03-22-2002, 10:39 AM
Gkafer
I have a question that maybe some of you can help me with. I called the dealer but they cant give me all the info (he cant find the info) I have two outstanding campains and need some info on them.
Campaign 96010 lower control arm ball joint.
Could someone please tell me if this is just a replacement of lower ball joints or is this a upgrade to the larger ones. The crappy part is i just replaced the stock ball joints last week!
The other is,
Campaign 96005 rear lower control arm. Is this just a realignment of the location holes? or is this a replacement?
Any info would be greatly apreciated.
post #2 of 2 (permalink) Old 03-24-2002, 08:08 AM
It is simply a check to make sure the balljoints are torqued properly. More than a few of them left the factory improperly torqued.
The Rear LCA one is the "upgrade" (and I use that term loosely) that was done to the arms in the middle of the 96 model year. Just upgrade to aftermarket lowers.
