Need picture of BMR rear sway bar installed - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 08-22-2003, 01:14 PM
mtxpert
I've got to get an idea of how much clearance is there. I had to remove the stock swaybar today for under the axle exhaust clearance... [img]smile.gif[/img]
Thx
Mike
post #2 of 6 (permalink) Old 08-22-2003, 01:58 PM
The BMR bar is a clone of the HA bar. As such, it hangs quite a bit lower in the areas your exhaust runs.
In other words, if your stock bar hits this exhaust....no way in hell the BMR bar will fit.
post #3 of 6 (permalink) Old 08-22-2003, 02:13 PM
mtxpert
I need to find a sway bar that bends up and is at the same level at the axle....
Mike
post #4 of 6 (permalink) Old 08-22-2003, 02:21 PM
mtxpert
I think I found what I need...
http://wolferacecraft.com
Should work great as I have room behind the axle now for the cross bar and I have plenty of room for the linkages etc.
Mike
post #5 of 6 (permalink) Old 08-22-2003, 08:32 PM
spaughman
Hey, I am curious why one wants to run the exhaust under? Enlighten me [img]smile.gif[/img]
post #6 of 6 (permalink) Old 08-23-2003, 12:46 AM
Basically, it's a bitch to get everything to line up "just right" so it won't hit anything (while moving) with a 2.5" exhaust. And with 3"....well, good luck especially considering the "precision tolerances" these cars were built to
In other words, Mike traded off the swaybar clearance (which is basically "none" now with a conventional mount bar) for an easier time running the rest of it.
