Metco RCAs and ICM brackets installed - Chevy Impala SS Forum
post #1 of 17 (permalink) Old 02-16-2004, 03:57 PM
nj96dcm
Thumbs up
This is the link to the pics. This install didn't go as smoothly as planned but it worked out. Here's the details.
The old bushings I had were totally shot, and they took longer then planned to remove, airtools rock. The old parts looked like crap when I compared them to the Metco stuff, but i'm sure you all know that. I used 90 degree zerk fittings for the uppers since that made the greasing way easier. The ICM brackets didn't move at all after they were isntalled(there's this lip on the mounting area that makes rotating them back impossible), so welding them up was no problem since they were pretty solid.
First thing I noticed during the test drive was the way the car felt. It was very solid and made you feel the road alot more. I left the rear swaybar off, and I don't think i'll need it, it also went into the dumpster with the old RCAs. The car does not spin as much, so the engineering part of these ICMs is working. The car hooks like it did before I had the converter installed, that should give those who have had a higher stall converter installed a better idea of how good these ICMs work. It just feels strange, but a good strange. I will have to get to the track this coming weekend if they weather holds out to test. Best with the Pilot Sports are low 1.9s, so if I get into the 1.8s, hopefully 1.7s, i'll be very happy. Looks like more suspension tuning for me, but it's always fun to get the car to launch hard on street tires.
Well that's it from here. If the pics don't load up blame Yahoo, and I just uploaded them so it may take an hour or 2 for them to become available. These RCAs and ICMs kick major butt, and it's another mod that done to get me ready for the ECIRS race next month at Cecil County. Next up, 1.6 rockers/springs/pushrods/seals, maybe an electric waterpump if I have time. [img]smile.gif[/img]
post #2 of 17 (permalink) Old 02-17-2004, 11:04 AM
Mike454SS
Steve, you don't think a rear bar could possibly help the car hook anymore? Do you have any pictures of the install?
post #3 of 17 (permalink) Old 02-17-2004, 03:41 PM
nj96dcm
As far as the bar helping the car hook up, I guess the extra weight might help, but no cars that I have seen that use this type of ICM/RCA setup require the bar to help out during the launch. I can't remember if Joe A. has the sway bar on his car since he runs the same setup last time I checked. I am also not sure if he has stock length RCAs like me since most guys get the extended versions. This setup is just like the SSM lift bars, and none of the G or A body cars I have seen have the rear swaybar installed, and most of them run 1.5-1.4 60' times on small tires.
I can say that they help out more then I imagined with the icy weather we have had since yesterday. The car is alot easier to drive and hooks harder in the crappy weather. I can get on it when I want after the car gets going and not worry about wheelspin in the rain. It also feels better around corcers and alot of the creaking noises I heard before are gone. I guess the ultimate test will be at the track next time I go. I can't wait.
post #4 of 17 (permalink) Old 02-17-2004, 05:31 PM
Dads95ss
What is an ICM bracket and what does it do for the car?
post #5 of 17 (permalink) Old 02-18-2004, 08:10 AM
Mike454SS
Cool, good luck with it. Keep us posted with how it does at the track. I am interested in instant centers for my car, but I don't think I can give up my rear swaybar...in fact I want a bigger one...I want the car to go around corners more than I want it to hook.
post #6 of 17 (permalink) Old 02-18-2004, 08:14 AM
PRoz
Mike,
I've got the Metco ICM brackets on my car except I have Hotchkis extended arms and the Hotchkis rear bar. Here's a pic from the rear My POS
I'm only cutting 1.7 60' foots
post #7 of 17 (permalink) Old 02-18-2004, 08:55 AM
NeverFollow
The only negative side to running with out a rear bar would making sure the car launches straight, but that's nothing a set of air bags can't fix. [img]smile.gif[/img]
post #8 of 17 (permalink) Old 02-18-2004, 10:13 AM
buffman
can those intstant centers be used with other control arms? Such as the stock ones, or do you have to modify them..
Matt
post #9 of 17 (permalink) Old 02-18-2004, 10:30 AM
PRoz
Matt,
They are made to be used with Metco Arms which are thinner than most aftermarlet and stock arms.
I'm not positive, I have never installed a set, but I believe they send washers to make up the difference.
I had to machine the spacers and bushings in the Hotchkis pieces to make them fit the metco ICM brackets.
post #10 of 17 (permalink) Old 02-18-2004, 12:54 PM
BTW, in the newest issue of GMHTP (in the article on Tulsa) there is a half-page pic of Paul's "POS" getting crazy on the road course at Hallett . In the pic, you can clearly see how the rear bar hangs down lower with the ICM brackets.
Dads95ss : the brackets change the axle-side mounting point of the lower control arms. This in turn changes the rear suspension geometry (for the better) as far as straight-line launches go. Not sure if it'll help or hurt in the twisties, but suspect it'll help (all other things being equal).....I'm thinking of getting a set to experiment with.
The biggest drivability downside is that your rear swaybar ground clearance is significantly reduced (see Paul's pic).
