exhaust w/ fast bags question - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 09-27-2004, 07:28 PM
Eyedalise Images
Does anyone have duel exhaust straight front to back w/ fast bags or hydros? I would like to know if the car sits on the pipes, muffler, cats, anything.
post #2 of 5 (permalink) Old 09-27-2004, 08:53 PM
choppednshaved
A competent(sp?) professional exhaust shop should be able to do anything you need, but the answer is yes, there are quite a few bagged and juiced cars that have them
post #3 of 5 (permalink) Old 10-06-2004, 08:00 PM
95WHT9C1
After bottoming out quite a few times in my caprice going up driveways, over speedbumps and etc etc. Let me tell ya that your car will ride on your exhaust unless you have it moved somehow - my exhaust hangs a whole pipe diameter below the frame so it seems. It sounds like coins in a tin can at a stop now - it's not being held properly so it shakes and rattles at idle ... hope this helps.
post #4 of 5 (permalink) Old 10-07-2004, 03:39 PM
lsvtce4thgen
mine is juiced and lays and when i drag it the only thing i had problems with was the cats hitting especially the passanger side one. i had an exhaust shop tuck it up and now im good.
post #5 of 5 (permalink) Old 10-09-2004, 08:35 PM
grocerygetterguy
hey Josh...it won't work, trust me I know. Mine is cut off just before the bags and we welded turn downs so the heat wouldn't affect the bags. Hope that helps. John
