Best Bushings for Bags? - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 08-17-2004, 06:05 AM
CHV_FRK
Any input as far as the best bushing for use with bags?
Since you are traveling through such a range of motion I was wondering if poly is still the best choice? Just curious as to what others have done.
post #2 of 7 (permalink) Old 08-17-2004, 05:54 PM
CHV_FRK
No one knows? Man I guess I just need to get it done and figure it out after.
post #3 of 7 (permalink) Old 08-17-2004, 05:57 PM
Same as for a "regular" suspension : Global West Del-a-lum. Hell, probably more-so due to the range of motion of a bagged setup.
post #4 of 7 (permalink) Old 08-17-2004, 06:11 PM
CHV_FRK
I have GW lower rears, on my wagon now, but I also have a set of U/L BMR arms.
Should I stick with the GW arms in the back, replace the pumpkin bushings with new rubber, and to del-a-lum up front?
post #5 of 7 (permalink) Old 08-17-2004, 06:21 PM
That is what I could do in that situation, if the bushings in the pumpkin are worn out (mine were in surprisingly good shape when I pulled them out last year). Might consider getting a NEW pair of stock uppers while you are in there, they do wear out and a pair of new uppers is only about $65 from Dal.
post #6 of 7 (permalink) Old 08-17-2004, 10:18 PM
CHV_FRK
Replace the BUSHINGS or ARMS?
post #7 of 7 (permalink) Old 08-18-2004, 12:04 AM
Replace the arms (which are $65/pair), and inspect the bushings in the axle. The bushings in the axle are a bear to remove if you don't have the right tool (I see that someone "bumped" my thread about the right tool today.....costs $80 but literally saves HOURS of work).
