front springs - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 08-28-2003, 07:34 PM
pinto2003
Unhappy
I took my car in to get a alignment, and they told me the spindle was bent and springs were bad. so, I replaced spindle and stock 95 ss springs from napa part #277-1132. Now they tell me they cant align it because my car sits to high.It looks lika off road race car. does anyone know what springs I need to make it look normal again? Thanks for the help.[/EMAIL][email protected]
post #2 of 2 (permalink) Old 08-28-2003, 07:55 PM
96DCMSS
Well, make sure you have the correct springs from NAPA.....maybe they gave you caprice ones. If they are correct, make sure they are installed properly. The bottom of the spring MUST be turned all the way to cover the first hole in the Lower A arm....the second hole should be visible. Then make sure the top is centered in the pirch correctly. Hope this helps, Good luck and welcome to the forum.
