Gear Box ? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 07-30-2004, 08:09 PM
Ill ss
I got a gearbox from da dealer ,how hard is it to install!? Am i better off having sum1 else do it? Looks kinda easy!
post #2 of 4 (permalink) Old 07-30-2004, 08:29 PM
CMoney
It's only 3 bolts on the frame, but the ABS deal is in the way making it a little tougher. Overall not that bad of a job though.
post #3 of 4 (permalink) Old 07-31-2004, 01:15 AM
Rustic
It's a little more than just 3 bolts... but it's not bad.
You will have to remove the steering shaft first.
You'll have to also pull the pitnam arm off the old one and re-install it on the new box.
Removal of the fluid hoses can be fun... especially if it's a high mile car. I had to use a torch to heat mine up before they would break loose.
post #4 of 4 (permalink) Old 08-01-2004, 10:28 AM
Ill ss
done ! big difference ! thanks!
