Front end rebuild - shock! - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 08-20-2004, 01:01 AM
96greengrey
I just finished pricing Moog steering and suspension parts and it looks to be $300 to $400.
If I ordered everything I wanted for the steering suspension and brakes it comes in at $700.
Problem is this is a 93 chasis I'm rebuilding and most if not all these items need replacing.
The Moog prices seem to be compairable to the GM/ACD prices in the Bill Harper "ACDelco suspension parts" thread.
With the body off the frame I want to do everything and not be crawling around under the car later when the body is back on.
What parts and were purchased have others used that are cheap/affordable and satisfied with?????
I'm looking at steering linkage, control arm bushings(front and rear),ball joints, etc.
post #2 of 6 (permalink) Old 08-20-2004, 06:12 AM
Navy Lifer
Facts of life--parts (new & used) will only get more expensive over time. An out-of-production vehicle is an opportunity to raise prices, as it costs manufacturers more to produce smaller quantities of replacement parts that are application specific--prices go up to maintain equity in the effort (ie. profit).
Fortunately, many of the front suspension parts used in the B-body are common to a number of vehicles & years, with a fairly sizeable population still on the road, so demand is still there, even though cars/trucks using the parts are mostly out of production. 73-77 A-body, 77-up B-body, 70-81 Camaro, 75-79 Nova, 78-88 G body, S10 pickups, and Astro vans share(d) a number of parts--only Astro remains in production, and running gear/suspension has been revised, so I don't know if it still has any commonality with any out-of-production vehicles. Lower ball joint for Astro was same as Moog K6141 (5/8") as an example.
Moral: take care of your stuff, plan ahead. Remember, no one feels sorry for orphans in the car business.
Check vendor section, for starters:
https://impalassforum.com/noncgi/ulti...;f=18;t=001124
and there may be others. Have you checked with Dal?
post #3 of 6 (permalink) Old 08-20-2004, 04:51 PM
Kevin Varnes
That's really not that much money. Plus it's not like you have to replace those parts every 3,000 miles. I would focus on getting good quality brand name parts. You don't want to be trying to save a buck or two when it comes to brakes/suspension parts. If I recall when I last did the front end on my Crown Vic I spent about $350-400 for upper and lower ball joints, bushings, tie rod ends, pitman arm, idler arm, etc. You can shop around a little on price but not much. Usually Advance or AutoZone carry decent suspension parts from Dana and TRW.
post #4 of 6 (permalink) Old 08-21-2004, 05:18 AM
91L03HO
Call Dal, AC Delco, can't beat his prices, at least in my book!
Dave [img]graemlins/.gif[/img]
post #5 of 6 (permalink) Old 08-22-2004, 01:28 AM
Spartus
Go into the VENDOR/GROUP PURCHASE area and check out the group purchases on front end rebuild kits. You will save a BUNCH of money by purchasing everything as a KIT.
https://impalassforum.com/noncgi/ulti...;f=38;t=000039
Zack should be able to get you almost everything you need.
post #6 of 6 (permalink) Old 08-23-2004, 11:03 AM
Sublvr72
I got that same sticker shock when I rebuilt the 1/2 ton suspension on my suburban when I did my conversion from 3/4 ton. Not to mention I got ripped off on the 1/2 stock 30 year old suspension and payed $400 plus another $300 to rebuild it with new bushings, ball joints, and tie rods......
