Impala Front Springs Question - Chevy Impala SS Forum
post #1 of 13 (permalink) Old 10-12-2003, 10:53 AM
iiibdsiil
I bought a set of Impala springs, all four corners for $25.
I am looking at the front springs though, and they are bent. On each one, there are two coils that are pinched close on one side.
I am not sure if they are supposed to be this way or not, so that's my question.
Here's a pic.
Sorry it's so big, I don't know how to resize.
Thanks in advanced.
- Brett Smith
<edit> Hosted a smaller version for you. </edit>
[ 10-12-2003, 04:56 PM: Message edited by: FakeSS ]
post #2 of 13 (permalink) Old 10-12-2003, 12:17 PM
That is normal. That "pinched" side is the side that goes towards the top of the car when installed, and the bottom pigtail should be installed so that it covers ONE, but not BOTH, of the 2 small holes in the lower control arm spring pocket.
If the last paragraph just confused you, it's a good sign that you should leave the install of the springs to someone else [img]smile.gif[/img]
post #3 of 13 (permalink) Old 10-12-2003, 12:24 PM
BAD ROD
Looks to me like they were heated up to lower the car. That is not normal and I don't like the looks of them. I would not run them on my car.
Mike
post #4 of 13 (permalink) Old 10-12-2003, 01:56 PM
protour4ever
Yeah, I gotta agree with Mike, those don't look healthy. Ed are you looking at the mid point of the springs-that's the pinched area that concerns me.
post #5 of 13 (permalink) Old 10-12-2003, 04:04 PM
FakeSS
I agree with BAD ROD and protour4ever. Those spring do not look good to me. I put '95 Impala SS springs on my car and they didn't look like that. Those springs were almost certainly heated to lower the car, like Mike said.
I'm sure Ed was refering to the places on the ends of the front springs where the ends touch (or come very close to touching) the preceding coil. He is absolutely correct (was there ever any doubt? ) that that end goes towards the top. The point he makes about the holes in the bottom cup (pocket) is very important, too.
HTH
post #6 of 13 (permalink) Old 10-12-2003, 04:17 PM
RJI
Angry
Those are bad. I wouldn't use them.
post #7 of 13 (permalink) Old 10-13-2003, 11:24 AM
iiibdsiil
Thanks guys, I will find another set for the front.
Thanks for resizing the picture for me too FakeSS.
- Brett Smith
post #8 of 13 (permalink) Old 10-13-2003, 11:54 AM
Whoops! Yep, I saw the BIG version of the picture and just glanced to see the pinched part (which is normal) at the end of the spring. Didn't catch the middle of the spring!!!
Of course, everyone else is right here. Those springs are trash, throw them away.
post #9 of 13 (permalink) Old 10-14-2003, 03:31 AM
rzab
...but don't feel bad. $25 for the rear springs is a steal providing they haven't had the same treatment as the fronts.
post #10 of 13 (permalink) Old 10-14-2003, 08:11 AM
Mike454SS
Installing those in a car is asking it to suddenly snap and drop the frame to the ground...and most likely that will happen when you're moving and hit a bump, not stationary...not a risk I'd want to take.
