Lowering - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 03-27-2004, 12:17 AM
Terrymcp
If you can lower an Impala SS 2" on 18's and it is allready 2" lower than a caprice. Can i use a set of 2" lowering springs for an Impala on my Caprice and lower it 4" on 18's? Will the springs from an Impala fit a Caprice?
post #2 of 4 (permalink) Old 03-27-2004, 12:20 AM
buffman
Ill answer the easy one; yes the springs will fit. Someone else will have to answer the more difficult questions for you..
Matt
post #3 of 4 (permalink) Old 03-27-2004, 12:52 AM
Sublvr72
if you order drop coils for an impala and it is going on a caprice add 2 inches to the drop. example, if they advertise impala 1.5" drop coils, it would lower a caprice 3.5" inches. The springs are interchangeable. If you only want a 2" drop on a caprice, locate a set of impala coils.
post #4 of 4 (permalink) Old 03-27-2004, 01:02 AM
Terrymcp
Thanks for the info. I will try to locate a set of stock springs for an Impala.
