High durometer bushings - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 10-20-2003, 12:40 PM
altmangf
I plan on installing BMR stock length LCA's on my Caprice. The stock Upper control arms will be retained, but need new bushings. I want to use rubber bushings, not polyurethane, on the uppers. Are bushings available from GM, Moog(TRW), or other sources that have a higher durometer rating than stock?
post #2 of 2 (permalink) Old 10-20-2003, 08:24 PM
Jonny042
I'll tag onto this thread and ask why not just use urethane bushings on all 4 rear control arms?
My caprice needs a little tightening, and I wonder if a set of 8 rear energy suspension bushings would do a world of good? You'd have money left over for the front control arm bushings if you re-used the read lower arms.
Jon
