Front swaybar bolts revisited - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 09-26-2003, 01:11 AM
eqs_ss
I have read the previous solutions on the front sway bar bolt problem. All good ones but here is another.
The problem: The front sway bar bolts strip the threads on the frame when removed or when being threaded on. Even if you are using new front bolts as recommended there is a good possibility of stripping the threads on the frame. If the passenger side bolt holes are stripped you can put washers and nuts through the access holes already on the frame so that the bolts can be tightened. BUT if the threads on the driver side are stripped you are pretty much hosed. There are no access holes to thread a nut on to the bolt.
My solution: On the driver side I drilled one 1" access hole for each bolt in the frame. For the front bolt I drilled a 1" hole to the left of the current drain hole in the frame. The drain hole is located on the bottom of the frame to the left of the bolt hole.
Once that hole is drilled you can now access the bolt and you can thread a nut on the bolt.
For the rear bolt I drilled a 1" hole right behind it on the bottom of the frame. The gap between the rear bolt hole and the 1" access hole is about 1/2" to 3/4". Now you can access the rear bolt with no problem.
These new access holes also allow proper drainage of the frame.
I used stainless steel bolts nuts and lock washers.
Tools:
-You need a 1" or 1 1/2" hole cutter with drill bit guide
-Electric drill
Just another solution to a somewhat annoying problem.
Ernest
post #2 of 3 (permalink) Old 09-26-2003, 12:36 PM
SSSSnyder
I did the "tie a thread to a bolt and work it inside the frame so it is sticking out" method. I used smaller bolts (I think 3/8 x 1.5" vs. the original 10mm) so they would slip past the existing threads in the hole and although they should be tack-welded to the frame to hold them in place, I was able to thread and tighten the nuts on the brackets without doing it. For the back hole on the driver's side I used 2 threads on the bolt, one at either end, so I could use tension on the back side to get the tip to wiggle into the hole. Took a couple tries to get it right on the driver's side, but not a huge deal at all. Happy to know that my sway bar brackets are on there but good.
post #3 of 3 (permalink) Old 10-01-2003, 06:32 AM
sleepercaprice1
I stripped my bolt holes when I installed my front sway bar and tapped the frame for 7/16" threads and used a bolt similar to a header bolt- (reduced head). It cleared the mounting bracket just fine. If that hadn't worked, I was going to drill the frame out and weld in nuts. That would give you much more thread depth.
