Getting the Upper Ball Joint back together? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 08-20-2004, 05:16 PM
92CustomCruiser
I've got the rear air bags in and plan on doing the fronts labor day weekend. I have one quick question though. I plan on using a homemade version of the kent-moore tool to seperate the upper ball joint from the spindle to gain access. But I'm wondering when I go to put it back together do I need a press or clamp? Or does just tightening the castle nut down draw everything back together?
Thanks,
Robert
post #2 of 4 (permalink) Old 08-20-2004, 05:30 PM
threeimpalas
No special tool is needed for re-attaching the spindle to the ball joints. Just tighten the nuts to the appropriate torque specs. That'll seat the stud into the bore in the spindle.
post #3 of 4 (permalink) Old 08-21-2004, 03:12 AM
Sublvr72
most factory upper ball joints are riveted in, all of the aftermarket ball joints are bolt in. Simple as tightening 4 bolts on each side and your done
post #4 of 4 (permalink) Old 08-21-2004, 11:53 AM
92CustomCruiser
Thanks!
