Suspension Parts - Chevy Impala SS Forum
post #1 of 13 (permalink) Old 03-22-2004, 04:43 PM
maniac
Hey guys plan on replacing my center link and lower ball joints. Should I get these parts at my local dealer or just go through dal. Will the price be the same no matter who I go through
post #2 of 13 (permalink) Old 03-22-2004, 06:34 PM
LarryCigar
Aftermarket[i.e. Moog] is great quality & will save you $$, also.
Get the Moog "K6187T" Idler Arm too, if you don't already have it!
Good internet sales here www.rockauto.com
post #3 of 13 (permalink) Old 03-22-2004, 07:03 PM
bengston
post #4 of 13 (permalink) Old 03-22-2004, 11:46 PM
maniac
Ok Im confuse now, is moog parts better then GM/Acdelco parts.Why the moog Idler arm over the GM/Acdelco. Also this is for my 93 caprice
post #5 of 13 (permalink) Old 03-22-2004, 11:55 PM
Terry McManmon
I had a chance to compare front lower control arm bushings and the Moog and Delco parts are identical to the eye. Can't tell you about the rest of the front end parts, but I wouldn't hesitate to use parts of either label.
post #6 of 13 (permalink) Old 03-23-2004, 01:37 AM
LarryCigar
Thumbs up
What Terry said!
post #7 of 13 (permalink) Old 03-23-2004, 06:43 AM
Navy Lifer
Apologies in advance for the length....to a question nobody really asked!
It comes down to personal preference. Moog was "first on the scene" 5+ years ago when people started finding it necessary to replace parts in the suspension of their late B-body cars due to mileage-related wear or through trial-and-error in fixing little problems that only showed up when the larger wheel & tire setup on the Impala SS had wreaked havoc with the OE steering parts and/or bushings because we all drove the car like it was a race car (which typically receives much more frequent maintenance than a street car).
Over time--starting in about 2000, I recall, Moog came out with the "T" version ruggedized parts, which included the significantly beefier K6187T idler arm that still is the most commonly serviced steering system part on our cars. By now, however, if these parts (on "your" car) are still stock, and regardless of mileage on the car, if its over 50K, I'd be looking at all of the other wear parts in the steering system--especially the center link, and, of course, the tie rods.
Even replacing these parts is no guarantee that all will be "right", since the steering gear itself is prone to wear and mis-adjustment, so that has to be looked at with the idea that it may need some work, too--not something to do at home, for most of us, anyway. And then, there are the control arm bushings and ball joints, too....
With all that said, being one who has shared alot here, I discovered that GM, thru the ACDelco replacement parts line, was offering what I considered to be equal or superior components when compared to Moog--and while there are plenty of stores that sell Moog, it was very frustrating answering the many questions about "where do I find Moog/Problem Solver parts?". I had my own good source for Moog, but for me the answer was to tell everyone, via this Forum, that there are also parts you can buy from GM with standard GM part numbers (ie. Dal and others--and your local dealer) that get the job done, and by virtue of that fact, are "easier to get" than trying to figure out where the best local Moog source was for someone not living where I was. If you go to a GM dealer now and have them look up the B-body parts, you'll find that most of the original PN's for replacement suspension parts have been purged and replaced with the ACDelco service-line equivalent.
I have found that I am very happy with the ACDelco line of parts, which are sourced from Dana Spicer, and are the same parts sold by NAPA, and in the Spicer "Profeesional Line". I have had quite a few packaging errors from Moog (a Federal Mogul company) and with the GM parts, virtually none. Don't misunderstand, Moog makes good stuff--and their K6187T idler still has no equal. But, if you've looked at the pictures that Wayne Bengston posted of the ACDelco parts, you can see how nicely the parts are finished, unlike the Moog stuff. In general, I've found that the ACDelco parts have some features that I like better than Moog, especially the plating or painting of the parts, the polymer-lined (lower friction) full ball design of the ball joints, and in the case of the upper ball joint, it is a single part that is pre-assembled with a nice poly boot crimped into place, where the Moog equivalent comes as 3 pieces all held together by the 4 bolts that mount the parts to the upper control arm.
This is not intended as a selling job to have anyone stop using Moog. As Larry has pointed out, there are good sources for Moog out there. It is also true that some parts are identical, no matter what package they come in--as Terry points out, bushings are generally common, apparently coming from a single source, it would appear--and its not even Moog or Dana (try Clevite, which may be a subsidiary within Dana). Other examples: center links often look the same regardless of source, as do upper control arm cross-shafts (the offset version).
post #8 of 13 (permalink) Old 03-23-2004, 09:32 AM
LarryCigar
Talking
BH strikes again with a profundity of suspension knowledge.
I started using Moog FE parts in the mid '70's exclusively. It's a quality part that's never let me down.
With my present car, when it was time for some FE R&R, I bought[based on some posts by Bill] the following AC Delco:
*Tie Rods, Inner/Outter~both sides
*Centerlink
*Upper Ball Joints
I'm very satisfied, this is a heavy duty, quality line of replacement parts.
I also replaced the Idler Arm, and used the Moog 'K6187T', based on numerous posts from this forum. You'll be a believer when you match up side by side, the K6187T[make sure you get the "T" part number part, enhanced design], with the OEM Idler. HD BABY! It made a huge difference in handling over rough road surfaces!
post #9 of 13 (permalink) Old 03-23-2004, 03:35 PM
LarryCigar
Exclamation
I'd like to add this to Bill's remarks about accessibility of Moog parts.
I don't know about other parts of the country, but here in NYC, it's very easy to find Moog parts at independent auto part retailers. Where as the reverse is true with AC Delco[Suspension Parts], especially at reasonable prices.
For anyone living in NYC[or close surrounds], I have found a store in Queens, that stocks most of the ACD Suspension Parts, & at good prices too.
Ruta Auto Supply
30-09 35th Ave.
Long Island City, NY
Tel. (718)729-4955
Of course if shipping wait is ok,
there's always Dal(877)448-5451,
or www.rockauto.com~only Moog in most cases,
you may wanna call on ACD availability
post #10 of 13 (permalink) Old 03-23-2004, 07:32 PM
maniac
Hey larry what do you mean, when you said "make sure you get the "T" part number part enhanced design". Is that a separate part from just Idler arm. Plus I want to thank those who answer my queston.
